Did you not say a RB25 hybrid? Or is that the type of turbo, a hybrid of a RB25 turbo, not the engine.
I am putting a 3076R on a stock RB25...but it will have 740cc injectors, and a kickass ECU. Just a matter of booking the car in, and handing over about $1.5k to have it installed and tuned :P
The difference in response between the 3071 and the 2871 would be less then 200rpm but will give you more headroom for future mods. Infact Powertune in NSW and Street Forced Performance in Vic have developed a 3071 kits for SR's that are as responsive as a 2871r if not more responsive. I'll find the thread;
EDIT!! Here you go
http://www.nissansilvia.com/forums/index.p...howtopic=406078
Edited by D_Stirls
Took some pics of the new toy yesterday .... pity it was raining and filthed it up before the photos (despite it being washed 2 hours earlier :P )
Fave photo
I was outside in the rain, rinsing my car off, so once the rain stopped i didn't have any dusty watermarks, the joys of living off a dirt road.
random "update" of my "progress". just copied and pasted from my ns thread cause im lazy.
i decided id stop being lazy and start fitting my oil cooler today.
i also decided id go with a relo instead of just using a sandwich plate. having trouble picking a spot to mount the relo though, so if anyone has any suggestions, that be great.
a view that is becoming all too common with this car...
new billet alloy earls relo block;
roughly where the core will sit;
and where the lines will be routed;
the mess of fittings off the permacool spin on adaptor;
(that bung in the straight fitting is a port for the temp gauge, blocked up til i get it...)
almost finished, need to mount the relo block, buy a filter, buy 1x 90 barb fitting, 1x 45 degree barb fitting, some straps of aluminium to mount the core, and itll be done.
so the kit now consists of a permacool spin on block adaptor, an earls billet relo block, an earls 19 row cooler, a whole bunch of random fittings, and 3 metres of flame proof line. bit more than i started with. lol.
and a random lol;
Edited by scandyflick
im totally bringing my gameboy out of retirement for pokemon!! WOOOT
lol I cranked out the N64 for Zelda the other day. Still got my SuperNes aswell including all the classics like super Mario world, donkey kong 1, 2, & 3, yoshis island, plus many more.
if you get modded xbox the old 1 anyways u can get any nes, super nes, ds and some n64 games on it.
works much better than using keyboard on pc ;)
and there are these things called emulators that prob work better than your webpage for it.
mario allstars ftw
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
