from 120 thru to 180 the downward line shows that it was dropping from 14.7psi down to 12psi at WOT in top gear
That's the torque curve not boost; and torque will almost always drop off in the top end as you have past the point of Max' VE (volumetric Efficiency) and rate of change of power has began to decrease i.e.torque.
Here's an example; these two print outs are of the same runs; one showing torque and the other showing boost. See how the boost is dead flat but the torque is still dropping.
Edited by D_Stirls
Thats sweet Craig. and by "drove a VT Commodore" i hope you mean "watched you have sex with Megan Fox"
hahah strange night indeed. One of those only half sleeping nights. Had the laptop next to me waiting for downloads to fin all night. Hence weird dreams.
I only really remember you being in my front yard. drinking. then kicking the wheel of your commodore with your foot.
I woke up today and thought to myself 'wtf'
i can't see how unless they are rated higher. First i would look at whether the factory solenoid is still in line if it is then bypass it and it MAY help a bit. But the others are right a EBC is your best bet as they minimise wastegate creep and do a much better job at controlling boost.
If you twist my arm i might even sell you my new one that has only done 500km since i'm looking and changing to a Turbosmart E-Boost 2.
P.S> so is your car Auto or Manual?
Its a Blitz DSBC Spec S.
That power is low then since your car is a manual.
you should be pulling a lot better numbers than that graph of my mates, because the only mods done to it were; Full 3 inch exhaust and FMIC, that's it. Doesn't even have a boost controller, Hence the boost curve . So it's running standard factory fuel and ignition maps it's just with the freed up exhaust and intercooler they run up to 12psi.
So even on 10.5 psi you should be closer to 200kw than you are.
Edited by D_Stirls
yeah stirls, I know its a torque curve, ... being my car and all the tunes etc I just happen to know at that point of time with that tune the boost dropped off as described
alls good now tho
:D
So if I were to put a FMIC on my car which is stock except for the 3" turbo back, I could go to 10 psi without any other supporting mods?
with his car that is what we found, though every car is different and if you have a look at the graph it's a far from ideal boost curve.
Also before you go out and start flogging around with your new found power is't probably a good idea it chuck it on the dyno and run it up to see if the AFR's are acceptable in your case. Nissans are generally VERY rich under boost though.
Edited by D_Stirls
I'm not interested in huge power figures and 'flogging' it but just want a little more acceleration. At the moment it hits the factory 5psi by around 3K RPM since the AM split dump and Cat have gone on, just want a gentle extra shove so to speak. I haven't done the hi boost mode mod to the car yet either.
FMIC, full 3" exhaust, I'd put 12psi through a RB25 anyday providing your injectors and fuel pump are in good enough to keep up which unless you have a good ear for pinging even sometimes you can't hear it I would do it all on a dyno so you can watch A/F ratos through out rev range and accurate manifold pressures (boost pressure).
Yeah, i only tuned it to 10.5psi to increase the life of the turbo. 12psi is at peak efficiency for a stock rb25 turbo.
Okay you know how sometimes you see car accidents and you think... how??
Well this afternoon, there was an accident in my suburb, which resulted in a Commodore suffering rear end damage next to a bent power pole. Sounds straightforward huh? But there was a car trailer with a car on it, upside down behind the Commodore - as in right behind - but the Commodore was on 4 wheels. Hope everyone was ok.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
