check this thing out and their whole website. Want a 34R NUR with 18km on it?
http://www.zeleperformance.com/vehicle/r34...registered.html
I was at Zele in yokohama 2 weeks ago and had a look at it in the flesh!! ..... heres a few snaps.... 34s everywhere!
Should had gave me a msg on Facebook! I would had come out!
I hardly ever use facebook man, otherwise I would have haha.
Another time,
Dave bring on the mid week runs ftw I had a ball last night it was great.
Jarrad - some advice if you are looking for a R32 GTR. These cars are all pretty old now and if I were you I'd be looking for the following items (unless you want a standard one).
1. Sorted the oil pickup problem. I would look for a larger oil pump & a larger sump &/or baffle kit.
2. A R33 GTR long nose crank (or with a collar).
3. New turbos with steel wheels.
4. A rebuilt engine with forged internals - mainly pistons, piston rings & conrod bolts. The standard conrods are fine for up to 400rwkW.
BTW if you want 18x10" rims then you also need to consider what size & look of tyres you want. 275/35/18 will need the guards to be rolled. 255/35/18 will give you a stretched look. I personally wouldn't get anything wider than 9.5" (I have 18x10 +20 BBS LM rims on mine) as 10" rims also prevent you going to full lock when turning.
I say all this coming from experience (i have owned 2x R32 GTRs since March 2004) and the experience of many (but not all) others. It may cost you more $ to get a car with these mods but I promise this will be less than the dollars, time & heartache when one of the engine or turbos blow.
balls. id love to come for a run, but with the new pump in im not gonna be "driving" it until i get it dyno'd to check the afr's...
... and ive got a going away party that i "have" to make an appearance at...
... on the plus side, ive sold my spare wing... and the front end of the 200 is back together. :thumbsup:
lol, pretty well. its come a fair way from the stocker it was when i bought it...
... now i just need a pfc or something and a z32... hmmm...
Edited by scandyflick
hahahaah yeah i need a sump baffle :thumbsup: but if not sitting at high rpm all the time not too much of a drama
who wants to go for a cruise tonight?? ive got today/ tomorrow off.
I may be keen later on tonight if your still keen Jenkies?
HMMZ i might have to give it a miss actually guys, been playing pretty sht b ball lately so i better get my ass to training. would say can cruise after training but its pretty dodgy car park there and ill stink up the gtr :)
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
