Dan, that is the poorest excuse ever :).
Does anyone know the exact way to get the dash out so I don't have to remove parts that dont need to be removed, I am changing dash lights and the lights that go where the hazards are etc.
Quick little tip?
Cheers :).
Edited by Weezy
I meant Inline6 Haha.
But your keen, good good. Jenkies Keen, Mad.
3 of us makes for a nice little group.
I am not mad keen on a full on hillzy touge spec my rear tyres have inner wear like a madcunt but I am keen on heading out.
Dash removal - R32 - How :).
cool so chronic wheezy inline6(is a pussey)
wheather is lookin a bit pooey anyone know if its gonna be a clearer night tomorrow. this is starting to look like a 32 gtr fest so possibly try and get as many 32 gtrs together as possible and head out tomorrow night??? get some photos :)
I had actually already planned to meetup with a few other mates aswell for tomorrow night I can't ditch them and be like 'Sorry guys, hanging out with RB26 crew' haha.
If it stays clear tonight Jenkies I don't see why not tonight haha
Dan, that is the poorest excuse ever :) .
Quick little tip?
Cheers :) .
Did this a couple of weeks ago, remove about 4 screws on the top of the drivers side panel under the steering wheel, pull it down ever so gently as to see about another 4 screws under that holding the bottom of the instrument surround in, then 2 screws up the top and 2 screws, one under the headlight switch, one under the wiper switch. Remove the surround (be REALLY careful, 16+ y/o parts can be brittle!) then unplug cables. Instrument cluster is 4 screws and it will pull out + remove plugs behind.
EDIT: Im slack, its probably better to remove the lower panel all together, its an additional 2 screws down the bottom on the left hand side, 1 one the side where the door closes with a little dome cover over the top and 2 screws behind the bonnet release.
Found this aswell: http://www.skylinesaustralia.com/forums/R3...html&hl=r32
Im easy for tonight or tomorrow night aha,
Whatever it may be I dont care.
Either Zillafest as the man says tonight, or all car tomorrow night :).
Almost finished my LED instal haha, my finger tips hurt from trying to get plugs out :).
So much of the dash needs to be pulled apart on a 32, give me a 33 to do anyday ahaha
Nah I found it quite easy. I ended up replacing the entire front section of the interior anyhow (after I'd fitted the led's) so I had to take it apart again, and then had to do it a third time to fix the airconditioner actuator
-D
I went to change my demister globes etc and the socket types are totally different to what I got sent to me from ZeroPoint Electronics?
I don't know, I'll PM him and see how the eff they're meant to work lol.
Anyone cruising tonight or we gonna have a bigger meet tomorrow night?
Take the LED out of the holder he gave you and the globe out of the rubber thing found in the switch. Then cut down the rubber thing (because the LED's wires are shorter) and thread LED wires through, wrap around so the base looks like original but shorter and with an LED. Easy.
Are you doing your climate control? Thats trickier than the switches.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
