Already put the dash back together, where were you earlier when I needed you Dion? FFS :)
LOL, you shoulda gotten my phone number out of my Facebook profile :)
Unless I'm working I will go to Vilis tomorrow night, so I can show you how to do them if you want.
balls.
got the pump fitted, primed it, all was sweet, topped up the sump, turned the key, fired after about 5 seconds of cranking.
check for leaks.
gi-f**king-gantic leak spotted.
engine shut off 2 seconds later.
30 seconds of nosing around.
culprit found.
the spin on filter adaptor that outlaws assured me *would* fit, didnt sit properly. was impossible to see before hand, but basically, the o ring is sitting right on the lip of filter block on the engine.
lost a fair bit of oil in the 20-30 seconds it was idling.
taking it back in tomorrow to have a bit of a rant.
meh. at least its the adaptor and not the core or any of the huge number of fittings i have on that.
its undo 3 fittings, move lines, remove adaptor, mostly done.
as opposed to;
remove grill, remove headlights, remove front bar, remove intercooler, undo fittings, remove centre rad support strut, remove core.
do ppl pull the whole dash off to put the led's in? wow i only pulled out my centre bit.. took me all of 10mins to install my LED's
No, the pic I posted was when I ditched my bubbly dash in favour of a non bubbly one I paid $50 for :)
same. i hated the bubble, managed to score a 2nd hand dash for $100... badabing, problem solvered ;D
-D
-D
No bubbles in mine thank god.
So are people keen on something tomorrow night then since its too late now I dare say?
It wasnt really hard to find a replacement, mine came out of a GTR front cut. I have been told if they are not currently bubbly, that they wont go bubbly. Is there any truth in this? If I have to have my car parked in the sun I have a sunshade and leave both windows down about 1" and pray no bubbles appear lol
I've never heard that before, however there is a certain logic in that - the bubble only occurs when the glue deforms and the external layer separates from the framework - if you have a dash that is 20 years old already and hasnt separated, then chances are it'll be fine (touch wood - environmental factors notwithstanding)
Theres a guide on here on how to fix the dash but tbh I couldnt be stuffed doing it. I may end up getting an auto trimmer to redo my entire interior and they could probably reuse my old bubbly dash, remove the exterior (or cut and re-glue it) and then recoat the surface with lacquer, repaint etc..
My main issue atm is lacquering the hard upper weather strip - replacements cost $600 per side, so I'm hoping some resin will fill in the cracks and I can paint it gloss black to match the external surround
-D
Your doing a full resto style job on your GT-R ben,
When you sell it and pass one someone will be getting an extremely mint GT-R.
On the rear window the rubber, you know the little metal clip that sits almost perfectly in the middle, has anyone got one that I can grab, mines not there? lol
Yep. $20k i've spent on the GTR so far over the last 2 years. This does not count petrol or carloan, but it counts, raa, insurance, servicing, mechanical mods/replacements/upgrades, speeding fines etc.
I won't be selling it. I plan to be riding this car for the next 20 years... probably will get written off by some tossarse whos not paying attention, but fingers crossed it lives as long as I do.... one of the customers at my mechanics is in his 50's, has had the same XB ford falcon with an intercooled supercharger since he bought it brand new as a young man.... I drool over it, even if the paint is shit and there are some ugly bits - its ghetto porn; naturally Im not gonna let mine get that bad, and there are more improvements planned yet, but its all a matter of money - no matter how much I earn, its never enough ;P
Dunno about that, speak to koji at japanese import spares in windsor gardens, he has damn near everything (and hes gotten me some great prices on door seals which I may go for depending on lukes contacts :)
-D
HAHA! awesome work that he was attacked.
Personally, i enjoyed the middle section of the article where it says " Will the premier Twitter about this?"
Oh dear god.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
