Your ride height is far from low
if i had stiffer suspension it wouldnt bottom out.
these bilstiens, while being hard compared to std shocks, are spongy
writeoff can attest that when i was going to moonta last year, we'd hit a dip and my entire exhaust would bottom out on the tarmac and shoot a tonne of sparks, so much so that it ripped apart one of the welds on my muffler
its not about how low it is, its about how the ride height interacts with the suspension - i'd be fine if I had totally stiff suspension but thats not the case
-D
Need coilovers
would be nice, but i need something thats street legal - got any tips on something that
a) rides nice on the street
b) is legal (or can be engineered)
c) is firm enough to handle well
d) doesnt bottom out
I got bilsteins atm but theyre the basic version (and probably getting long in the tooth)
If it wasn't an issue of legality I'd just buy the ISC coilovers and be done with it
-D
*plugs antenna back in*
Safe to assume an 02 sensor shouldn't be doing that an its probably farked?
/noob
Thanks!
Well actually yes that's what a narrow band O2 sensor will do when the engine is in closed loop mode. If you look at the voltage output from a narrow band sensor there is a big difference in the voltage between 14.6 and 14.8 and all the ECU does is aim above till it gets a low voltage and then aims below until it get's a high voltage, so by constantly going above and below it averages 14.7 which what we are looking for.
-D
Just buy my Teins man, awesome awesome handeling, ride height was fine and never bottomed out on anything, legal, and is easily streetable - Ticks for every box :laugh:.
Like I said I'm in no rush to get them out of my garage and your more then welcome to put them in to see if they're what you want :(.
hey Dave i hear your car is looking heaps good now
can you pm me some pics ? :3
lol. its looking fully reasonable.
havent had a chance to take any pics yet though (only got it done yesterday), but ill be out taking a few snaps tomorrow night. so stay tuned.
awesome, my mate saw you drivin the other day , i look forward to seeing images! :ermm:
Just buy my Teins man, awesome awesome handeling, ride height was fine and never bottomed out on anything, legal, and is easily streetable - Ticks for every box :ermm: .
Like I said I'm in no rush to get them out of my garage and your more then welcome to put them in to see if they're what you want :) .
ahh brew ur twisting my arm eh brew
ok, are they off your car? I might see if my mechanic can fit it next week for me to test - I'll take it to and from loxton with your permission
-D
manage to find all my stock parts for my suspension. Hopefully i can get it cleared by the end of next week.
Main thing im worried about are the gauges, and fitting up a brake light to the rear window.
Yeah they're from my car man.
I don't see a problem with you taking them to and from Loxton, I'm sure someone has some details about you incase you do a runner - LMAO
*points to trader rating*
and sled knows where i live haha
-D
can I ask what steering wheel you had and what reason theyve given for it being illegal?
-D
I have a rear window brakelight out of a 32-R that you can borrow if need be. Ive been too lazy to put it in mine. Only need power and double sided foam to make it work.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
