hey Chad if you're serious we should go and see him together.....might get a better price for a couple of sets.
yeah, im serious. i want some new pipes before the turbos go on, im still pretty keen for those Greddy ones, just depends on the cost difference.
well i just need ones to suit 32, i have 34 front pipes now, so i'll have to modify my exhaust back to 32 specs. which should give me more ground clearance i hope.
Also dropped off my 34 gtr rims today to get painted, think im gonna get them painted the same colour as my Drift Teks.
so, got bored at about midnight, so i decided id take advantage of the half not shit weather and go out and get some pics of my car. found a pretty good spot out in port adelaide, and i stole petes spot in reynella :O, pretty cool for a church, lol.
shame the camera was acting pretty freakin weird for the last couple hours :P
we should probably just rig the lotto.
takes care of that 'work' issue.
that being said, i could go out, get myself a gambling addiction, have myself self-barred from all gaming lounges in sa, then claim work cover cause of my temptation to gamble while im at work :O
... yeah, rigging the lotto is a better idea...
is it the whole kit globes and igniters, becuase HID globes are different to halogen globes :O
Lol Steve of course it is the whole kit. however, i did buy globes to suit an R34 from 666DAN, then realised i didnt have factory HID installed, then i bought a HID kit to suit R34 minus globes.
666DAN
Yeah....666Dan, his kits are tops... make sure u specify if u need the aircon leds in addition to cluster/gauges...
also, i got an entire set of red ones that I took out to put blues in if anyone wants em
-D
Guest
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
