Errr Brendan - you do realise it is a GTR with around 450rwkw and has run low 10's? You would have kept within sight range for around 30 seconds, and would have been it :D
umm yer, you reckon I couldnt keep up in the twisties, being an ex-bike rider whos used to lines and 220+kmph corners?
lol, as said, $50 is a bet id take :laugh:
all in good fun
Im bored too... i hate exam time. One down today (animal health) got three to go.. sigh. I have business management for applied science saturday morning.. yes thats right an exam on SATURDAY MORNING! Adelaide uni is so mean :laugh: Can't wait until it's all over!!
Sez
Edited by Ryan&Sez
Im bored too... i hate exam time. One down today (animal health) got three to go.. sigh. I have business management for applied science saturday morning.. yes thats right an exam on SATURDAY MORNING! Adelaide uni is so mean :) Can't wait until it's all over!!
Sez
Far out thats just tired me out reading all that and i don't have to do any of them!!!
my other exams are animan nutrition and animal behaviour, welfare and ethics - that's the one that puts you to sleep!! I'm so glad that this is my last full time semester :)
Sez
Edited by Ryan&Sez
I can't believe it either.........I doubt if the block alone is worth $30K........maybe with very expensive internals ie. a short motor
Errr Brendan - you do realise it is a GTR with around 450rwkw and has run low 10's? You would have kept within sight range for around 30 seconds, and would have been it :)
You had better believe it mate .... BLOCK only. Definitely nothing else included. The crank that Munro is using was a cool $5k on top, then pistons and all the crazy gear incl. 1,600cc injectors - yes you read right. This is how he has spent $180,000 on the car. And yes, he has receipts.
Ring Keir Wilson right now and ask him - he has bought around 5 of the OS blocks all up due to blowing motors etc .... his wallet knows EXACTLY how much they cost .... I am not sure what exchange rate they were purchased at, but I am sure it was better than it is now too .... only recently he pointed out to me one sitting under his work bench at Willalls looking all lonely - I told him I would happily give it a home :) .... but as it isn't quite in my price range there it stayed :)
i found this 1,627,500.00 JPY (Japan Yen) = 26,404.34 AUD (Australia Dollars)
>>source>>
RB30 OS-E2996
Developed for those special customers who feel that 2.6 liters is just not enough.
OS Giken RB30kit contents
RB30 OS-E2996
- 1 cyclinder block
- 1 billet crankshaft
- 6 billet-forged connecting rods
- 7 crankshaft main bearings
- 6 connecting rod bearings
- 6 forged aluminum pistons
- 1.3mm metal gasket (1.2mm, 1.4mm and 1.5mm
gaskets available)
- 1 timiing belt
- 1 belt tensioner kit
- 14 custom made reinforced crank cap stud bolts and
nuts
- 3 M6 bolts
Guest
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
