I heard the trust type M dont need the fan blades to be cut.. Obviously you will still need to cut a hole for the piping on the side..
Or you could get return type coolers such as ARC.. But will be expensive..
Otherwise most cheap copies, will require you to cut a bit of the fan blades..
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3398401
Correct siddr20, the Trust ones don't need the blades cut nor do the GReddy's but I beleive they are the exact same just rebadged
So your sure that the Trust/GReddy ones don't need to be cut? even for the NEO RB25?
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399303
series 1 r33 here and i installed a JJR intercooler kit...didnt have to trim the fan blade and it doesn hit either...even underload
i believe the s2 is the same deal...although some people say that it hit, some say it didnt. If it doesnt have clearance you can always gently notch in a small dint in the underneath of the piping with a peice of wood to make it clear....someone i know did that and it clears now and no need for fan triming :rolleyes:
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399618
Just a get a Blitz LM cooler or ARC, with return piping so no need to cut holes or fan. And it should run more efficient since it doesnt sit above the rocker cover or radiator.
ok, noob question.. Return piping?? I've heard ARC are sweet intercoolers, but what is return piping???
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399880
Yep, BLiTZ M is good, thats what I have on my R32, well whats going ON my R32.
Attached a picture for you noob :thumbsup:
Thats the cooler that will be going on my R32, you can see how the piping comes to the one side.
Return flow is when the piping runs to one side of the car, and up into the engine bay the same way the stock I/C piping does.
Abu
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399965
I've got the Blitz LM kit on my R34.
I'm at work atm so this is the only pic I could find.
Sweet setup bro, what ius that thing just to the left (picture, not car left), of the intercooler??? Oil Cooler???
@ Abu.
I see mate, thanks!
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3401448
I'm gunna jump on the wagon too..
I also have R33 GTST S2, 40th anniverssary (though pretty sure it's the same)
Was thinking of getting greddy 300x600x76.
Should I expect any increase in lag with this cooler?
If so is it worth changing to the R34 GTT one?
I dont plan on going crazy with mods for more power in the near future, maybe just a pod filter and I already have 3" exhaust.
Also any other basic tips would be appreciated..
Thanks in advance!
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3401503
i've certainly noticed more lag after installing my fmic - eventually i'd like to go to a front facing plenum to reduce the pipe-maze a bit and see if it helps. also am going to wrap my return pipe in front of the radiator in heat-proof shielding to see how that goes cos that pipe gets stupid hot!
oh also have a jjr fmic and just bent the bracket that the return pipe uses to attach to the engine so it clears the blades - looks a little ghetto but looks aren't my concern.
Edited by made_guy
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3401566
Thanks guys..
I am also taking into consideration that I live in Alice Springs and it gets DAMN hot and dry. I don't know how this will affect my car...any ideas? I don't think it will be too much of a problem, maybe just a little loss of power..
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3402209
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
