  • Replies 47
not quite, if the remote dies and you cannot get it working again you are screwed..
that is why I prefer full alarms.
Silly question perhaps - I thought most (if not all?) alarms have overrides on them? As long as you have the key and can remember the generally obscure combination of buttons and actions (and recite an ancient latin text when the moon is blue etc etc... :) ) then you can at least get the car going until the remote is sorted out?
full alarm is easier to 'fix' when you destroy a remote key. the other way involves a trip to a dealer or in this case a email to japan to get a new key.
if you have two OE keys then upgrade is fine.
upgrades RELY on the OE remote key working. with out it no go.
  • 5 months later...
Can anyone summarise for me, I am still a bit perplexed.
Can you have the car opening/disarming and starting using the original key fob only, or can you use an aftermarket system instead?
I would prefer to keep the original stuff locked away and use something that can easily be replaced... can you make them both work?
As for only one key, that is a killer, I need a spare ready to go, just in case!!
in summary:
OE key can be used to control an upgrade alarm
if the alarm used has a fob then the OE key must still be used to start the car.
the OE key has a transponder inside it that controls the NATS system. no OE key = no go. had a call on that today - fellow lost his keys and wanted to start his car with a blank copy - nup!
make more sense now?
Controller Area Network- ln laymans terms - take concept of the internet and squash it into your car. everything talks to everything else via a computer command. break the link and it all comes to a grinding halt..
Don't even f**king start me on CAN bus f**kups.
I've got an Autowatch 446Prem (with integrated turbo timer) on my Z33 and, coming off the Brant, its a great piece of kit. Since I don't have my OEM fobs anymore I got Autowatch ones. I'm pretty sure the installer says they can integrate with the factory items (he also fits alarms onto V35s for compliancing).
Edited by scathing
Cheers Chris, so the OE Key has the door lock buttons on it, or are they seperate?
The OE Key is just a Key with a 'chip' in it that makes sures all the binary codes line up for the Starter to earth at the right time...
Simplistic of course, just like me...
no they are on it. exception is the red valet key.
your assumption is correct.
Cheers Chris!
So to completely clarify, the simplistic approach
  1. Is there an Aussie Key (Presume Nissan) that can be made to do all of the Standard Jap key functions, including open doors, engine start, open boot etc?
  2. What brand and model of Alarm can replace the Standard 'remote' functions listed above, along with the usual Alarm/Immobiliser functions?
  3. Do I have to have 2 black boxes on my Keyring (1 built in to the Key and 1 for the Alarm Remote of your choice)?
  4. Can I just have a basic key (Aussie Nissan with inbuilt transponder) and an alarm remote with boot release (depending on actuator installed on car)?
The reason I ask is, as a 'simple' man the only items on my Vehicles Key ring are a black box (alarm disable & central locking), Ignition Key (copied) to start car and a Siren silence key for hidden siren. Car will still not start tho.
I can't cope with heaps of stuff dangling from ignition or filling the pocket.
Edited by Stephen Thorpe
  • 1 year later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
