From what i was told is that you can not exceed 210rwkw with the just the housing being machined you need it to be larger. they said that once you change it for example if you put the avo one on there you will atleast get about 260 to 280rwkw.
Ah thats bullshit mate :O Whoever told you that have absolutely no idea what they are on about.
Countless people have made 250-260rwkw with the R34/VG30 rear housing with GCG Hi-flows, and other hi-flows from places like ATP, MTQ and so on.
These use the FACTORY turbo housing machined up to suit. So in 'flowed' form, they flow whats required.
A couple of people now (from Vic) have PM'd me with a similar questions, and i reckon its the same 'place' giving out this info as they dont know how to tune and are using the turbo as a scape goat.
Surely the sheer amount of documented results on this forum is enough to show you what they can produce easily.
When you think about overall costs, hi-flowing + AVO rear housing etc etc... I would be surprised if it isnt signifigantly cheaper to purchase a proper frame GT3076 or something and will do exactly the same job.
Pete - the turbo might also be nosing over due to the compressor, being the GCG used to be i two different sizes, and the bigger was stopped due to the comp wheel being too far over-sized and surged in a lot of situations
Ash.
Yeah, I wouldn't be doing anything with the back end until I install this temp gauge thingo.
But if it's only marginal, I wont be spending $850 on a few more kilowatts.
Much prefer to put away for a HKS2835 ProS...... Cos benno says so :O
I reckon a Neo RB25 could possibly get away with a real GT3071R and one of Garretts GT30 IW T3 flanged turbine housings . That way you get the exact same compressor wheel as a HKS GT2835 Pro S and the non cropped GT30 turbine . I think the Neo's variable cam timing could pull the bottom end up a bit better than the R33 version and thats probably why Nissan used the larger OP6 type turbine housing on R34 GTt's . Also with Garretts turbine housings the available A/R ratios are 0.63 0.82 and 1.06 , the 2835 Pro S's are 0.68 and 0.87 .
For a GT3076R I would always use one of the the above mentioned Garrett GT30 IW housings , a good chance you could buy such a turbo complete and know the housing is designed to suit the turbine . Once you move away from OEM turbine housings its generaly best to use one designed for the turbocharger , if you can get one that bolts to the std manifold the rest is pretty straightforward .
Cheers A .
Yeah, I'm very interested to see this as well.
LTHL. 210rwkw sounds about right from the STD housing, non high flowed.
My car (and a few other highflows R34s) seem to max out at 250rwkw and this is seemingly due to the exhaust housing.
oblivio we eagerly await your results.
Im talking about a hi flowed turbo 210rwkw.
Ah thats bullshit mate :) Whoever told you that have absolutely no idea what they are on about.
thanks for all your help guys i really appreciate it.
Edited by LTHL34
Is Nismoid trying to sell you something? No. Look at the motivations before you believe everything you hear.
I have a highflow GCG turbo on my car. The highest it has made is 272rwkw on a dyno dynamics dyno. It made 257 at Autosalon on the Mainline dyno after I had fiddled with it. Last retune to fix my fiddling was 262rwkw, again on a dyno dynamics dyno. It does 11mph at the strip and weighs about 1600kg.
i understand that mate, and im not trying to argue. its just that when i started asking questions about these things to mechanics i got these answers and thats why i wanted to hear your what all you guys had to say.
No probs mate.
I asked, a long time ago, an extremely well thought of workshop about highflows and was told that I would never get over 220rwkw. Well I made 228rwkw on 13psi through the auto my car used to have.
The sad fact is that it is extremely rare for a workshop to be totally honest with everybody. There might not actually be one in existence. On the other side of the coin, people on here are sometimes prone to exaggeration and shit talking. Unfortunately, each person has to take it all in and decide what to make of it themselves. Hey, it's part of the fun and the challenge of modifying a car.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
