Dont suppose we can get a pic to view the quality of the item? I've seen you around on the forums and you seem trustworthy enough, but always good to know exactly what you're getting.
https://www.sau.com.au/forums/topic/188688-apexi-safcii/#findComment-3401637
I can guarantee it's in good condition, no markings or deep scratching at all.
Wiring is all-perfect, and button works perfectly fine.
The screens on these SAFC's/RSM's and AVCRs are very delicate, and gather markings quiet quickly & easily, but there are no obvious markings on it :)
Packaging in mint condition as stated in original post.
Cant get pictures right now as I am at work, but if you really really want them, I will take some and post them up tonight at about 7pm when I get home.
Abu
Edited by abu
https://www.sau.com.au/forums/topic/188688-apexi-safcii/#findComment-3401658
Is this the same one you were selling in August? I just saw the pics on that one. Did the buyer fall through, or this a different one? Also does it come with a mounting bracket or anything like that?
I'm not 100% sure at the moment, I'll have a think about it anyway.. I've sorta got the money, but I know it could be better used elsewhere. Will let you know.
https://www.sau.com.au/forums/topic/188688-apexi-safcii/#findComment-3401686
Na different one, that one was sold back in August.
Unfortunately, this one does not have the mounting bracket, but you can easily buy one from the forums, about $15.
It's pretty much the same as the one in the pictures I was selling back in August, same box and condition.
Thats alright man, let me know when you are ready.
There a good little upgrade, especially if you have cooler, exhaust and fuel pump. Can put some more boost through the stock turbo and have it tuned to make some good power, not to mention better fuel economy and power curve/response.
Getting the car tuned probably gets awesmoe results.
Price is neg, so let me know, and I am always reasonable.
Any more questions, feel free to ask. :)
Thanks,
Abu
Edited by abu
https://www.sau.com.au/forums/topic/188688-apexi-safcii/#findComment-3401691
Will do a better price for anyone who comes and picks it up, so PM me a reasonable offer.
Had plenty of interest, but no one has come through with the ca$h! :)
Edited by abu
https://www.sau.com.au/forums/topic/188688-apexi-safcii/#findComment-3402136
DAMN!!! i was just bout to tell u i could take it by the w/e!!
Hahah sorry buddy, you just missed out.
There is another one for sale in the for sale section now, might have some luck with that one. He is asking the same sort of price.
Good luck with it!
Thanks,
Abu
https://www.sau.com.au/forums/topic/188688-apexi-safcii/#findComment-3404056
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
