Not sure if its anything to worry about but is starting to annoy me...When i start her up its take a fair while before it fires up like 10-15 seconds of turning over.
What Could be causing this? and is it easily fixed?
Cheers in advance
https://www.sau.com.au/forums/topic/188902-slow-starter/
get a timming light and some1 who can use it, and learn how to use 1... it's not hard and good to know...
Also i agree with NYTSKY go to ur local Batteryworld or similar, and get ur battery tested...
It probably won't (but could) be ur timming, but it is an easy thing to rule out...
batter is more likely.... learn how to check ur timming but..
https://www.sau.com.au/forums/topic/188902-slow-starter/#findComment-3405924
my guess would be the timming cause if the starter motor is spinning and turning the engine over the battery seems fine
are the lights on the dash on during this cranking process?
low battery levels can allow the car to crank, but not have the ecu and dash lights on which wont let it start
https://www.sau.com.au/forums/topic/188902-slow-starter/#findComment-3406079
