Reseached with no luck.
I bought a KKR430 turbo the other day and m just doing some research before fiting it to my r33 series 2. I cant work out the new V-band clamp and how it fits.
I got the dump pipe that fis it as well.
Has anyone fitted one of these and know of any other problems i may encounter along the way to fitting this thing??
Thanks guys.
Jase.
https://www.sau.com.au/forums/topic/188948-v-band-clamp-on-kkr430/
not sure what u mean about how it fits.
but if there is no bung in the dump pipe for your o2 sensor?
you will need that done before u fit it
The dump pipe conection is on the other side of the pipe so thats all good.
just think of it as a hose clamp, just make sure the clamp is over both sides of the flanges lips
Thanks. I think i know what you mean, theres just an extra ring dude left over when I get it to "work". Do I need to use gasket goo or something? Im concerned that it will leak.
Here is a close pic of the fitted clamp how I think it should be (note the hole on the dump pipe for the oxygen sensor) and the clamp on its own and the other steel part that I dont know where it goes. Did I get it right?
yep looks correct to me, V bands are more prone to leaking though
havent ever tried it but you could get a high temp sealer on that bead if your worried, gets used on 3 and 4 bolts exhaust flanges all the time
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
    • It's either an ignition failure or a fuel failure.
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
