Reseached with no luck.
I bought a KKR430 turbo the other day and m just doing some research before fiting it to my r33 series 2. I cant work out the new V-band clamp and how it fits.
I got the dump pipe that fis it as well.
Has anyone fitted one of these and know of any other problems i may encounter along the way to fitting this thing??
Thanks guys.
Jase.
https://www.sau.com.au/forums/topic/188948-v-band-clamp-on-kkr430/
not sure what u mean about how it fits.
but if there is no bung in the dump pipe for your o2 sensor?
you will need that done before u fit it
The dump pipe conection is on the other side of the pipe so thats all good.
just think of it as a hose clamp, just make sure the clamp is over both sides of the flanges lips
Thanks. I think i know what you mean, theres just an extra ring dude left over when I get it to "work". Do I need to use gasket goo or something? Im concerned that it will leak.
Here is a close pic of the fitted clamp how I think it should be (note the hole on the dump pipe for the oxygen sensor) and the clamp on its own and the other steel part that I dont know where it goes. Did I get it right?
yep looks correct to me, V bands are more prone to leaking though
havent ever tried it but you could get a high temp sealer on that bead if your worried, gets used on 3 and 4 bolts exhaust flanges all the time
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
