Whats the best way to polish a dished wheel? Ive got some Rays wheels that i want to paint the centres black and polish the lip, ive started using 1200 grit and brasso in a small section on the dish and its coming up smooth, but dull... how do i get the shine?
anyone recommend what sort of prep needs to be done for the wheel centres also?
cheers
i had my 4 stockies, sand blasted and powder coated for $180 the lot. about 45 per rim. in a pearl white. if u just getting centres done might work out cheaper.
with polishing, get a metal polish and use that. dont fuss to much with sand paper unless there are scratches all over the dish.
hey mate i just did the four of mine.they looked shit house and now there unreal.
1.clean rims.
2.wet&dry sandpaper 1000 until smooth
3.wet&dry sandpaper 2000 which takes away some of the lines that the 1000 left.
4.clean rims and use autosol and elbow grease your way to pretty good looking dish
doing just centre would cost you more, since there is more work involved in masking up the lips, then blasting then remasking them for the application of powder
simon-r32 - looks good mate
is there a place i can take my rims to.. to do something like that?/ repaint the center and polish the dish again as mine looks really.. dirty
and i wouldn't have a clue of how to do it myself...
in vic as well..
just curious as to the difficulty of it, my Works use a bolt head that i havent seen as a bolt head before.
wasnt an Allen key or Hex head was it? Most are like this.
Its easy enough to pull them appart, most rims have a sealant (3 piece ones anyway) in the middle, and also when re assembling they need to go back the same as you pulled them apart to keep the balance of the rims the same.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
