Hello all...
I got a canary the other week... While I was working, while my car was parked in a car park on private property, I wasn't at my car, and to top it off, it was done by the TMU.
Is that possable, can the cops do that???
Any way to cut a long story short, one of the four things I got done over for was ground clearance. My muffler is about 97mm off the ground... and not 100mm!!! - I think I speak for everyone when I say this... BASTARDS!!! :P
And what I am asking is, does any one have a site that I can go to where I can find the factory grould clrarance for a R32 GTR.
My mate thats doing the RWC says that an R32 GTR comes out lower than 100mm (I really don't know) and he says that if I can prove it then all I have to do is show it to VIC roads and I get off on that one.
So if any one out there in Skyline world can help me (and the guy doing the RWC) prove the factory ground clearance is lower than 100mm, then I will lick balls... NO I WOULDN'T! ...I will just thank you heaps and heaps.
If your all wondering what I got dicked for it is...
Foward sharp projections - I didn't have a front bar on and the reo bar was showing. (I had a small stack a while back)
Drivers vission obstrustion - I have dog tags hanging from the mirror and apparently I cant see the road. ;)
Drivers instruments obstruction - I have a boost guage on my steering columb and apparently I cant see my dash. :thumbsup:
Ground clrarance - My muffler is 97mm and not 100mm
I have one more question... I haven't touched the ride hight of my car at all, and I got the 15 year rule compliance thing done and have all the paper work for it. Is that enough to get me off the hook???
Thanks
Justin.
https://www.sau.com.au/forums/topic/189154-canary/
97mm what basterds.
Not sure about the defect on private propery? That would mean a cop could defect you if you were working on the car? odd
Jack your car up to lift the rear wheels off the ground. This will uncompress the rear springs.
When you place the car back down, the car will sit higher before they get compressed by the weight of the car
https://www.sau.com.au/forums/topic/189154-canary/#findComment-3409829
man that's all superficial stuff, just put the bumper on, get rid of the rice and jack your car up. no stress. bit harsh they got the car while parked tho... they are allowed to though.
https://www.sau.com.au/forums/topic/189154-canary/#findComment-3409843
Very bad luck mate. Car park on private property, i dont think they're allowed to do that are they? i mean meeting regulations and all is fair enough , but thats when the car is on the road, or at least parked on a public road! Even though you could sort out those defects, i would confront the bastards about the issue until someone with some sense there realizes whats happened.
I mean what if you had a club lock on the steering wheel or a sun shade covering the front window, is that an obstruction defect as well :)
https://www.sau.com.au/forums/topic/189154-canary/#findComment-3409846
In VIC the police are entitled to come into a private property as long as there is no gate or door they have to open to get in... if there is then they'd need a warrant or sufficient evidence that its necessary. So they can come into your driveway, or walk into a carpark.
https://www.sau.com.au/forums/topic/189154-canary/#findComment-3410888
Ok fair enough, but if it was a private carpark im asuming there would some kind of tollgate on entry and exit, i wonder if that could be argued.
I guess its like that there as well, they were righting up defects last night at a Maccas Car park here in NSW, wether you were near your car or inside eating didnt make a difference to them...
https://www.sau.com.au/forums/topic/189154-canary/#findComment-3411198
The reason they defected you was because you had no front bar on, which from experience they really don't like.
Hence why they were c**ts about it and picked on ride height, 97mm PFFT! and the other little shit. Did that make it a Major? Require a RWC?
Edited by bryyy
https://www.sau.com.au/forums/topic/189154-canary/#findComment-3413543
Yeah they got me for 4 things so its a Major Defect... I put my car up on a hoist and checked out my exhaust to see if i could lift it any higher. And it won't... So i think i need to raise the car 10mm, get bigger rims or a new exhaust.
Does anyone know where to get one of them tool things to adjust the suspension? I got JIC Magic.
OR Does any one have spare 17 or 18 that i could slap on for the day while i get the RWC and get rid of this canary? ;)
https://www.sau.com.au/forums/topic/189154-canary/#findComment-3421948
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
