Hey im probably going to get a k&n air filter but just wanted to know do you hear any sucking noise compared to a pod filter??
i just got my car imported and it was serviced with a new air filter so i dont know what to do yet but its a recaro brand filter.
https://www.sau.com.au/forums/topic/189214-kn-filter/
hmmmm thought so :domokun:
i want low-mid torque for launch n that but i want the sucking noise too
A pod filter doesn't really mess with your low-mid torque at all.. That would have more to do with your exhaust,clutch,tyres in most circumstances..
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3410373
but doesnt k&n give u better response when accelerating and pod filter give you better top end speed or high end torque something like that
It's been said by some members on the forums here that they've noticed a little lack of low torque after putting on a POD.. But I think the gains/differences aren't that noticable.. You're car just breathers cleaner, should run a little more efficiently, get more km's per tank of fuel. I had a boxed POD with cold air intake on it on my old 33 GTS. That seemd to give me the best of both worlds.
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3410397
yeah if i go with pod im gone need heat shield and good setup so it breaths cold air properly...and im not to good at all this stuff
There's a member on the forums here called Maxx he makes and sells the boxes for R33's anyway it just replaced your stock airobox, encloses the pod, has a clear plastic top so you can see in and still keeps the stock snorkel feed.. See below. If you wanted to get more out of it I'd set up some PVC piping or something from the front bar to blow underneath the pod aswell.. More air can't hurt.
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3410446
i have a yellow paper panel filter on my r34 im not sure what brand it is but it was on it when i got it. anyway above 4000rpm i can hear a sucking noise it sounds pretty cool. and in my old car i had a k and n air filter and it used to make more of a whistling noise, but both weren't really loud but you could hear them without the radio on.
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3410572
I started with the stock airbox, went to a pod in a cold airbox with cold air feed, and then back to the standard air box with an Apexi panel filter.
When I changed back to the standard air box, I could notice the following:
- less top end pull
- much better lower end torque for day to day driving
- quieter
If you decide to get a pod, definitely get a heat shield and pipe some cold air to it. I'd recommend a dry/paper filter, not an oiled one like K&N. In a test the Apexi filter had the best filtration and flows just as well or better than the others. It is dry so you can just blow it out with an air compressor when it needs cleaning - ie no messy oil kits.
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3419844
I used to have a Apexi power intake pod but recently noticed it was dirty so i put the stock air box back on again. The car runs the same, if not better (smoother?).
I could only hear the suction noise if the bonnet was open otherwise i really didn't notice much of a suction noise that everyone goes on about. IMO save your $89, spend it on something else :D
btw you might find this useful, it gives a comparison on the different brands: http://www.mkiv.com/techarticles/filters_test/2/
Edited by shaun123
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3420960
I could only hear the suction noise if the bonnet was open otherwise i really didn't notice much of a suction noise that everyone goes on about. IMO save your $89, spend it on something else :)
You should have cleaned your pod!! It makes a massive difference.
I agree that the Apexi pod does not make much sucking noise, but it is louder than the standard box.
hmmm i have my mind made up one minute then change hahhaha
$89 Apexi Pod
or around $100+ for K&N panel filter
i still duno yet :)
im sort of leaning towards k&n Panel filter
I'd go with the panel filter :)
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3421670
I find the K&N panel filters to give better responsiveness. As a daily driver I just find something like this to suit my needs. But if your really out for the the intake sound, go for the pod, but as everyone said, let it at least have some cold air feed.
Just wondering what pod filter to get on my 34 gt
I want a sucking noise
which pod delivers on that... personally i was gonna go blitz but not sure
what you guys think???????
tahhh
Most likely the Blitz and K&N Pod's. I haven't used apex'i but as far as I can see it won't be as noisy as the two brands. Though I've heard that some cheap brand Pods use cheap oil which can make the sensor dirty reducing performance.
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3440003
just changed from k&n panel to apexi pod. found the pod to be heaps better and fixed the problem of oil slowly getting onto my air flow meter and stuffing up my a/f ratios. if your gunna use a panel use a dry one, not oiled. :O
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3440038
i was thinking that aswell... thatnks for the help mate
cheers bud
https://www.sau.com.au/forums/topic/189214-kn-filter/#findComment-3440050
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
