hi guys, before i get a auto electrician to have a look, any advice on how i could keep why light not working?
I have already changed the bulb, even used the left side bulb to make sure its not just a dead bulb. also i noticed the high beam not working also, so im sure something work with that side..... Parker light still working....
Anyway just some advice guys and if i cant fix it, please give me a name of a auto electrician or someone that can fit it for me.
thanks guys
steve
https://www.sau.com.au/forums/topic/189299-driver-side-head-light-not-working/
hey dude, I'm writing a tut on one of the many ways to fix this problem at the moment buts its not finished yet. its pretty simple so don't pay an auto-lecy money for a job you can do yourself.
i found the problem to be in two places, firstly the roller switch which operates the parkers and the standard beam lights (SB) and then further a issue with the contacts on the back of the mech that controls the High beam (HB) on/off and the pass function.
sometimes on the roller switch the the little heads that push the contacts up and down either snap off or become worn with age which means they don't push the contacts together enough to turn the light on (both lights have individual contacts). i pulled the roller switch apart and cleaned it up and fixed a broken head by making one out of Areldite (spelling?) which fixed the lights for a good while but just last night the problem came back.
this time i traced the problem back to the HB control in the steering column, its really easy to pull out takes 10mins its only three screws. on the back of the mech there is five contacts on the far right side are the contacts which control the SB on and off, the far right one is for the Passenger side beam and the next one on the left controls the driver side SB. try turning on the ignition to ACC and then push the contacts down this should turn the light on and pulling them up will turn the light off.
this is as far as i got today because i got to go to work/uni but when i finish i will post up a photo filled solution to this common/annoying problem.
NB: for a quick fix, flick your high beam controller to pass a few times and see if is enough to make better contact as its only a crappy plastic mech which lifts and depress the contact that would wear with age for sure.
NBB: if the contact gets hot after a few mins of playing around it means its not contacting proper and cause resistance which makes it get hot
NBBB: everyone should own a Multimeter they are worth every penny
there is some fuses in the box under the steering wheel, and there are some larger fuses in the fuse box in the engine bay. i own a 32 so they maybe in slightly different spots and positions. my fuse box cover has a diagram which shows whats where but its in Jap so i can only make out the H/B.
is yours in English by any chance?
also what would you like a pic of exactly? i got heaps haha
hey mate!
ok i would really like to check if the fuse is blown so here is a quick pic i took of the fuse box in the engine bay. im guessing the fuse for the lights r here but which one i got no idea!
One mate said he thinks its one of the small ones on the right side of the big blue one on the far left bottom corner... there r 4 small ones 2 red (which have the number 10 on them) and 2 blue (number 15 on them).....
will get a better pic later if needed
Edited by steveyea
not sure exactly which is which but there is a fuse for each light, get a pair of needle nose pillars, or something of that nature and pull them out, they should just pull straight up, try not to bend them from side to side if you can.
if the fuse is popped it will look substantially different to the other ones. pull all four out one at a time have a look at it, put it back in if they are all ok then the problem is more likely to be at the next junction in chain towards the cockpit, either a switch or a fuse are the typical weak points.
if the fuse is popped, you can get replacement ones from Supercheap/Repco/Autobarn all those good places. the number on the top indicates the AMPerage of the fuse, if a 10 is busted you need to put a 10 back in that spot.
keep us posted!
  • 6 months later...
hey guys im having a similar problem and its my fog lights driver side isnt working
i wanna know where the fuse is for it i looked in the boot dosent have say for fog and i cant read jap
under the dash of the steering wheel so it might be dere and the one in the engine bay dosent say fod ligts but i tried the right hand head light but i dont think that connects to the fog light dose any one know which fuse is for the fog light cheers
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
