Fs: Gizzmo Launch Interface (ign Cut), Gizzmo Shift Light, Adapter Loom - Plug Straight In! (all Rb's)
Item: Gizzmo Launch Interface (IGN Cut), Gizzmo Dual stage Shift Light, Adapter Loom for RB25 (will most likely fit a RB20 and RB26 too)
Age: 3 months old
Condition: Like Brand new
Price: $420
To Fit: (What car) This will fit a RB25, but I am 90% sure it will also fit a RB26 and RB20, will check and get back to you.
Contact: Via PM or email. PM for email address, or post in this thread.
Comments: This works 100%. Used it in my RB25 GTS-T and worked a treat. I could make 10psi of boost with my GT3076 at 3500rpm in neutral.
Shift Light setup is so damn easy, as is the launch control RPM setting.
I have made a couple of modifications:
1. I have added the option of a clutch switch (this requires 12v power). There is even a plug that will plug into your existing clutch switch under your dash.
2. Adapter loom - This is worth $180 (part of the package). Its soldered all ready to go. Just plug it into your factory harness and set it up, and off you go.
Also, this shoots some good flames when RPM cutting :D
Please feel free to ask any more questions.
Here are the pics:
New, I paid $440 for the Launch interface, and Dual stage Shift light, and an extra $180 for the adapter loom. Then I spent about 2 hours making the loom up and creating the clutch switch circut.
Thats a total of $620 plus labour to install this (could be nearly $800 after installation).
I'm selling for $420. I'll shout postage.
thanks.
Edited by The Mafia
Pretty keen to know the above meself
Have the launch control interface but not the shiftlight yet sitting on the shelf at home
If you can do a bit better on the price pm me
its a Field One touch connector. Same connector I use to re-wire so that I can make a RB26 Powerfc work in a RB20 and RB25.
I can't really do any better on the price because:
Launch Interface and Shiftlight: $400
Field one touch connector: $180
Two hours for me to make the adapter loom:$0 or someone else ($150)
Brand new you're looking at $700+ for this.
  • 3 weeks later...
btw this is sold to me, works a treat! Thanks mate
throw flames? I'd possibly be interested in something like this down the track...
  • 5 weeks later...
Hey mate, I'd be interested in the loom and connector as I have one of these on the way.
  • 4 weeks later...
very rarely.. but they updated the firmware so its not so violent anymore.
Can you please explaing to me in detail what te Gizzmo Launch Interface does? Kinda lost..
Edited by Dush
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
    • Hey all, Noticed I have a hole on top of which im guessing is my transfer case/gearbox. I can see it from the middle of my firewall looking down. S1 R33 gtr Any advice or can pinpoint what this is/caused this?
    • Looks like you were right on the T pattern! I did that and it's finally fixed! Thanks a bunch.
