Gtr R33 For Sale
Nissan Skyline GTR VSPEC 1995
4WD RB26 TWIN TURBO 5spd Manual
50,000ks
JET BLACK colour
bucket seats
320k White Nismo Gauges,
HID Clear Lights,
Apexi Power fc,
20" Deep Dish Rims with brand new tyres a few weeks old have reciept
Twin HKS Pod filters power everyting,
High Flow S/Steel Cat
Brand new front and rear ccx racing pads paid over $800
Full Brambo brake system
Icy cold airconditing
Just serviced and tuned
SHOWROOM CONDITION $25000
rego
safety cert
0439 660 860
Location is GOLD COAST
CAN SHIP AT BUYERS COST
Email- [email protected]
No trade ins or silly offer please
Pics below-
Edited by 1050HPGTR
https://www.sau.com.au/forums/topic/189591-sold/
its nice but i wouldnt say cleanest GTR in aus. i seen better a minute ago when i looked at the white stock as a rock one thats still factory spec.
all though i like black n if had the money would buy it.
g/l with it mate
https://www.sau.com.au/forums/topic/189591-sold/#findComment-3439648
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
