Installed this a while back.
The installation was REALLY easy, alot easier than what I have read on here.
Basicly you had to grind off one nut hole off the exhaust manifold where the heat sheld screws to and every thing else just bolts up.
Stock oil lines hocked up perfect and I just blocked off the water lines.
I didn't need to bend the actuator rod like some people have said.
Here are the results.
https://www.sau.com.au/forums/topic/189849-kkr480-on-r33-gtst/
I also run a kkr480 on my rb25det and me and a mate installed it ourselves,
turbo bolted up perfect, just had to grind a bit of the exhaust manifold, oil lines bolted up, but i went into enzed and for $30 or so he put new ends on my water lines to match the same size thats on the turbo, then i just chopped the lines and used high pressure/heat hose 2 move them around to fit nicely, and towed car to my mech 2 get dumpipe fab'd up and cooler piping change a little,
comes on hard bout 4000-4500rpm, i just run actuator spring which is bout 1.2-1.3 bar of boost, bit hard 2 control boost in these things, only downside..
but worth every penny, ive done bout 5000-7000kms alredy on this turbo, runs like a dream
Yeah it has got a GMC or some Aus turbo reco company bandged on it. I dont think its GMC but that just comes in to mind, its some 3 letter name.
Yeah KKR480s aren't that big, this one came off my VS commodore V6 and that spooled it at 2800rpm for 12psi. Its around 3000rpm, well you feel the boost kick in hard as then look at revs and its doing around 3000rpm. will have to have a closer look.
Its definarly a KKR480 I brought it new.
Any way stock turbo isn't big enough because I want 300RWKW.
Also I did lean the living daylights out of it early on to help turbo spool.
Well not that lean like 13.7:1 Air Fuel Mixture.
Edited by Finny
Yeah I would get a boost controller if I was you, adjusting that actuator rod would be a nightmare.
I didn't think you could get 1.2-1.3 bar out of the stock actuator as my commodore running stock actuator on the KKR480 only saw 12psi tops.
Does it over boost at all in high revs? I am hoping I dont need to get the wastegate cut out so it flows more.
Ummm the enzed bit makes no sence... KKR480s are oil only.. I just blocked off my water lines. The stock oil lines seemed to bolt up perfectly.
finny mate, you sure got a 480 cause no way it would spool up that early and also if its a oil only turbo then what are the other two fitting in the turbo core for????. you might have a bitsa turbo cause every 480 ive seen has oil and water fittings
Also you will be very lucky to get your 300kws with a kkr480 they arent bigger enough for it.
Edited by nick81xd
:S
Mine is from JustJap its marked as a JJR480 but I thought they where just rebadged KKR480s... they look identical.
Maybe I am wrong.
It has only got oil holes.
ummm that sucks... I should have got one from otomoto :)
KKR 480 =
Yes I can see the water holes on that one
JJR480 =
Ohh well looks like I will be going to a Garret GT35/40 later on down the track then.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
