For those of you who want your fuel pumps delivered earlier please make payment ASAP, I have sent you all a PM with payment details.
Any questions or anymore orders please dont hesitate to PM me.
Cheers,
Johno
  • Replies 41
Cheers,
Johno
can you please put me down for a braket also?
Thanks
Justin
Hey guys,
The order has been placed, you should recieve your pump(s) by the end of the week!
Malecki - your one will be delivered shortly as arranged earlier.
For others interested, the group buy will be running until the 19th.. so theres still time to place an order.
Cheers and thanks for making this happen!
Johno
Hey N1GTR,
Im pretty sure the bracket is for external mounting of the 044 and 040. I am getting Cyber to confirm whether it can be used intank.
To mount intank you would use your existing (stock) intank bracket and modify it to suit the 044. Theres a DIY on here somewhere.
Cheers
Johno
Ok the following peoples fuel pumps have been sent via Express post today.
Flash89 - 044 x 1 Bracket x 1
Walkoau - 044 x 1 Bracket x 1
Rinmak - 044 x 3 Bracket x 3 (two satchels)
Tizzle -044 x1 Bracket x 1
If anyone else is keen the group buy will end on the 19/11.
Cheers
Johno
my 044 arrived today.
thanks for organising this group buy Johno....best group buy ever, good price, fast order+delivery.
thanks
JUSTIN
thanks
JUSTIN
Awesome, glad to hear it reached you safely..
Thanks mate sounds like my first group buy was a sucessful one!
Cheers
Johno
Johno
any chance of getting approp parts numbers/sizes for fittings needed? as in m18x1.5 to hose tail end (for ease of installation)? maybe we could also get these at a discounted price from cyber?
thanks
Justin
Received the pumps yesterday. All very nicely packed and very prompt delivery.
Thanks alot for taking the effort to do this for us Johno. It is much appreciated and you have done an awesome job! :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
