I just bought some new turbos for more power so these need to go.
There R32 N1 turbos with no leaks.
Brand new stainless dump pipes with seperate wastegate tube plumbed back in. To suit 33gtr but can I can supply them to suit 32. The exhaust gas sensor is a different thread thats all.
Also a really good pfc tune to suit this setup.
I was running stock afms, injectors etc and they have made 292.5rwkw but I had the pfc retuned to a safer more through tune using the injectors and timing maps not just tuning off the afms and it now makes 280rwkw and has seen a little track time with no detination.
If you bought this setup all that would be needed would be a little tidy up of the tune to suit your car. Maybe 1 hours dyno time instead of a full remap. Save big $.
I'm after $1000 for the lot which is cheap considering if your ceramic turbo shits itself an engine rebuild is 5g plus and you also get more power. They are still in the car atm.
Phone if your really interested
Gareth 0417370869
Melbourne
It rises up to 20psi and it drops off to 18psi up top so max about 1.3bar. We couldn't get the boost controller to hold the boost up there but in a way it reduces the chance of killing an engine at the higher rpms so its not really a problem.
These turbos have really good response on the track and at motocarna's so it gives the car really good traction/drive out of corners compared to a few cars running singles and there also nice on the street.
If your after really cheap power you can't go past this setup. Its kept me more than happy for the last few years.
I don't know about when they start making boost and full boost but I can tell you that it makes full boost way before a gtr with a to4z due to how it pulls away out of corners and when it was overlapped over a gtr with 2560-5 turbos with around 10rwkw more power the power curves were almost identical apart from the 2560-5's making about 5-10rwkw more once the power graph began to rise.
Hope this answered your question in a round about way. There is no problem with response. Its all about your right foot and how good you are. What are you planning on using the car for? I have used it for track and motocarna and have had performed very well with what I have and have had no problems with lag at any time.
Must go. any offers
hey mate,
i am running a stock R32 GTR, was thinking about upgrading the stock ceramic turbos.
what mods did you have when you got 280rwkw?
i am only looking at replacing the turbos and getting a FMIC and Power FC i dont want to have to change internals.
Brezza you already have a fmic and its good for over 350rwkw so keep it. Save the cash for an exhaust system and cam gears and the pfc and you have the same mods as my car. Replacing the ceramics is a great idea. I've had a exhaust wheel go through a rb26 and its not cheap to repair in a old car. As for internals there are guys in the club running 350rwkw out of rb26's with stock internals so the N1's will be fine.
hey mate,
is the N1 just a rebuilt stock turbo with better bearings and steel wheels?
also what boost were you running to get 280kw?
i would be aiming for around 260kw, something a little more safer and something i can use without stopping for fuel all the time
Brez
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
