HI guys looking at selling my rims to make way for some new ones. They're Volk racing light wieght 3 piece. imported them from Japan. 16 X 8 +30 and 16 X 7 +30 (i think). ill double check that when i get home.
The tires alone are worth 600 bucks a corner (Potenza RE01-R's 225 back 205 front semi's) and are the grippiest things ive ever used. They are a Jap tyre and can't be bought from australia. They shot me to a sub 2 sec 60ft time with 160ishrwkw. Sit perfectly on a standard 180sx
Looking for around $800ono. price is negotiable so let me know ur offer. no. 0431 466 113
cheers,
-Brendan
Edited by Big_fella300
https://www.sau.com.au/forums/topic/189968-volk-racing-3-piece/
hmm by the looks of things he's from VIC (by the plates) and probs a 4stud unless a 5stud conversion has been undertaken...wouldnt seperate the tyres would ya?
pretty easy to redrill i believe. not sure on price but not overly expensive. ill try to find out for you. may separate the tires depending on price offered. let me know
cheers
-Brendan
redrilling is easy, keeping the wheel strength is a different story i guess. any wheel repairer could do that for you easily. freight is going to be something circa the $150 mark pretty much aus wide using freight company for infrequent usage (businesses get better deals coz they are frequent users)..
how much tread of the tyres? to tell the truth im only after the rears at the moment coz the front ones are way too small for me. i will PM offer depending on tread. thanks brendan
looks like it will be somewhere between $80 to $120 to redrill. any local tyre place should do it. i know tempe tyres will. and as i said, the center caps cover the studs anyway. let me know if you're interested.
cheers
-Brendan
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
