start with a 6 gapped small, move to a 7 with a larger gap if you want to play around. 8's are good for race meets only with a suitable gap of around 1mm or so.
I'm running 7's with a larger gap as opposed to a small gapped 6, it is better for power once you have boost and suits my driving style.
https://www.sau.com.au/forums/topic/19000-haltech-e/#findComment-400977
Cool thanks will give it a go, just trying to avoid having to purchase extra coil packs thats all. At the moment it is hard to tell as well as the Computer has not been fully tuned. Cold starts and the Fine tuning of the computer have not yet been completed. All I know is it drives like an absolute dog. Is it safe to drive?
https://www.sau.com.au/forums/topic/19000-haltech-e/#findComment-401022
