Wrecking R33 Gts-t '97 Model-offer To Sa First
As per other thread I am wrecking an R33 gts-t '97 series II White, 70,000km front end damage, offering to SA ppl first. A;; items will be in very good condition unless stated otherwise, all bolts/nuts etc included with individual parts.
Thought I'd post it here rather than in the sticky for sale as it would clog that thread up, happy to move post elsewhere if the moderators want me too.
Link to all pics labelled and in here---> http://s127.photobucket.com/albums/p148/PT15/
(if no pic found then you should know what it looks like already)
Entire boot lining (including floor and wooden piece) $100
Tail lights with globes/wiring $200pair ($150 each)
Rear centre garnish (says SKYLINE) $75
Boot sound deadener $40
Rubber seals for door shell L&R $80 ($50 each)
Rubber seal for boot shell $40
Weather strips L&R with all clips $50
Climate control unit $80
Cluster/odometer (showing 70,036km) $100
Cluster plastic surround $40
Glovebox complete $50
Dashboard with top vents undamaged (as per pic) $150
Centre console $50
Stereo/gearboot surround $50
Plastic door piece (says "SKYLINE") $80pair
Roof lining $80
Cabin carpet $100
Sunvisors $30 pair ($20 each)
Rear vision mirror $20
Interior lights both $30 ($20 each)
All interior surround plastics with x3 grab handles $150
Rear parcel shelf with speaker covers $80
Front seats $250 pair (passenger x1 small cigarette burn)
Rear seats $100
Seat belts with brackets/bolts $200 the lot x5 (or $100 front/$100 rear)
Rear reo bar (undamaged) $120
Boot with adjustable spoiler (see pics) $250 complete with gas struts etc (spoiler alone $200)
Rear bar few light scratches (no cracks or dents) $150
Rear pods $50 pair
Side skirts (L damaged bracket at back, R damaged at front...see pics) $50 pair
Rear wiper $20
Rad and A/C clamps $20 all 4
Horns x2 with wiring $30
Greddy M-spec cold pipes for FMIC (only cold side) $80
Turbosmart Type I BOV with R33 adaptor $100 (with boxes and instructions etc)
Greddy turbo timer silver (in box with all wiring/instructions) $100
Gizzmo EBC with manuals/wiring etc $150
Viper alarm (?1000 model??), complete with all wiring and x2 remotes $150
Jap cat-back exhaust (appears 3" to 3.5 or 4" haven't measured it) $350
Razo shift knob $50
Greddy water spray bottle $75
Speco boost guage (mechanical with cup holder, silver 52mm, reads to 30psi) $75
Anything else not listed is on the car still and not yet available, other thread has list of damaged/unavailable parts on page 2
ill take the cluster m8. pm your number or call me on 0404 232 231 cheers clayton
Vu you cant put dibs on the spoiler as i have already said i wanted it in the other thread
oops sorry about double post, Vu we can discuss things later if you come online and see this try and ring me my number is in my profile
Price for passenger side door only - no glass or trim required. What is the paint code?
still on the car, will sell with no trim and may remove window, don't know price yet, factory R33 Series II White, no dents but there is a chip the size of a 20cent piece on it
pics of pods coming...probably on Thursday
Edited by PT
does yours have any holes or any thing on it? coz i want another one to replace the one ive got now coz ive got a hole in mine coz the boost gauge was bolted there.
how's $30 sound, assume you mean the A-pillar (some have boost guages attached etc)
not too sure will get back to you
do you have the A pillar with the gauge holders?
no
How much for the drivers side front window? Also, if the bootlid is not taken, how much for that?
bootlid/spoiler combo is already taken
not sure what drivers window is worth?
yeah yeah yeah pics of pods and other pics coming soon, they will be posted up on Thursday (tomorrow) around lunch time.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
