  • Replies 60
Posted Images
no mate no dyno sheet but its not hard to see by lookin at other cars and compairin what has been done if needed will get a dyno sheet
Edited by DRR33
Wow...
so it made 258HP (192.5kw) on 6psi
and 320HP (238.8kw) on 18psi.
But it makes 402HP (300kw) on 10psi like you said before?
Must need a tune..
Or does the turbo start turning backwards after 10 psi?
Maybe you can go back and edit your BULLSHIT posts.
then have a moderator delete this post for bagging out your bullshit lies.
+1 lol
very strange thread indeed.... drr33, not so sure im a believer of what is being said here lol
id love to see some of these dyno sheets... you seem to have a nast hole in your power after 10 pound
+1 lol
As i have said before this is what i got told when i brought the car by the owner and by the company that built it i put it on the post cause i hadnt had it dynoed yet and as iv said i will get it done again if it is needed
thanks
hey mate not sure how much power its making but ive been told that its will make 400hp+ atw, going to strip this weekend for qtr mile time, got 5 spoke 17s, body is good but needs paint has been painted by previous owner but needs to be redone, no sunroof, there is more stuff on the car than i said but cant think of it.
this is one of my fist post if u read it u will see that i said ive been told that it makes 400+hp.
so once again if u dont like whats in my post keep it to yourself
hey mate, i got a r32 gtr carbonfibre wiiiidebody. with new 10-point cage, bride seats, NEW g-gram wheels 315/30/r18 semislicktyres. all this thing needs is a engine. which maybe can arrange. i got a complete rb25t manual package or s15 sr
cannot be registered though. perfect racing car.
pm me if interested in more info
Edited by IMPORT-G
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
