Hey all, kinda new to the GTR scene so i have a bit of what may seem a stupid question, i dont know that much about this kind of thing.
Ive been driving skylines for a while but my previous two have been an r32 GTS and r34 GT. With both of these cars the clutch and brakes have been very light and fluid, however with my GTR the brakes arnt too bad but the clutch is quite heavy, now i was wondering if this is because of being a 4wd, rather high performance car, or if my clutch is just crap.
https://www.sau.com.au/forums/topic/190288-gtr-clutch-and-brakes-question/
You may have had a stock clutch previous cars? Most of the GTR's around usually upgrade the clutches to a heavy duty. Nismo make a cylinder that actually makes it a lot softer.
- D_I_F
Have you asked the previous owner??
If you felt my pedal its hard to push it in and heavy and mine clutch is upgraded ;)
More then likey you would have a heavy single in there..
Do you have alot of play in the clutch when engaging or is it on or off??
Not alot of play in it at all. gear change is just fine..a little sticky when putting in into first on a stand still, oh and i get a wee squeeling noise if im in traffic conditions taking off going up a hill.
i have a upgraded clutch cylinder in my gtr and my clutch is heavy as!!!
i have a twin plate clutch which is probly the reason for it being so heavy, and when your not moving and i put the clutch in i can hear a metal on metal rubbing noise, and it also squeels if you try ride it, it's on or off.
my mechanic indicates that if you can't hear a rubbing noise when you put the clutch in, it's a single plate clutch cause they buff out the noise where as a twin plate doesn't.
they should both squeel when they are being ridden, this is a indicator to stop riding it or your doing a big launch which is putting some pressure on it.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
