  • Replies 91
Posted Images
Nuts! What about front ? Rubbing anywhere ? :D
17x9.5+18 driftek on the front.
10/8 coilovers on full hard take care of any scrubbing issues. rear guards are pumped as much as possible without buckling.
still some slight scrubbing issues on the inner guard but the hammer will sort that.
well i have 17*9 + 20 and they sit out of the guards a fair bit. I'm running 235/45/17.
an extra .5 inch would make it .25" on either side of the wheel (6.4mm) then the +18 offset would make it sit 2mm more outwards (compared to mine). So it would be a total of 8mm more than mine.
Also, being 18" instead of 17" would make them closer to the arch in terms of diameter.
Nothing a bit of guard pumpage and tyre stretch won't fix.
Edited by daisu
  • 1 year later...
I've trial fitted some 17 x 9 +10 Work Meisters (F = 215/45/17, R= 225/45/17) from a mate who is selling them. I love the look of them on the car :( , but just a little concerned about how much rolling/pumping of the guards will need to be done, primarily to the rear with the door aligning so close to the guard. Currently I'm only getting some light scrubbing on the rear with a bit of aggressive driving. How have you guys gone with rolling/flaring of the rear? much paint cracked? or what are yours thoughts as in would I be better off going for some different rims with a better offset?
I've trial fitted some 17 x 9 +10 Work Meisters (F = 215/45/17, R= 225/45/17) from a mate who is selling them. I love the look of them on the car :D , but just a little concerned about how much rolling/pumping of the guards will need to be done, primarily to the rear with the door aligning so close to the guard. Currently I'm only getting some light scrubbing on the rear with a bit of aggressive driving. How have you guys gone with rolling/flaring of the rear? much paint cracked? or what are yours thoughts as in would I be better off going for some different rims with a better offset?
He lives! :D
Edited by konect
haha sure do ryan! Gave up on the car scene for awhile with other interests but did a deca day recently and feeling the bug again.. :P
Got your ceffy on the road and registered yet?
As of Tuesday...YES!! :wave:
Check out my members ride thread. Will post new offset pics after the w/e.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
