Hey Guys
In the stages or tearing my engine down, ready for a rebuild.
There are a few retailes of RB30 Rods at the moment
- SPOOL
- ARGO
- Rod Factory
But whats got me confused is
Centre to Centre: some have 152.5mm and some have 155.5mm
Will either of the 2 work?
Anyone else come across this and what have you done
JD
https://www.sau.com.au/forums/topic/190554-rb30-rods-height-make-a-difference/
Brad I spoke to you this morning about that, thanks for your help
Rods Factory, i know they are on ebay are 155.5mm
RacingPartsfactory.com also have them as 155.5mm
Will using the 155.5mm Rods pose a problem? I know they are 3mm longer, i am planning on using CP 8.2 Flat top Pistons with them
Edited by D1AUS
Umm yes - the pistom will protrude 3mm out of the bore and you wont be able to bolt the head on.
It just wont work - you will need to get a custom piston made to suit.
But from my calculations, it is ok.
RB30 Specs
RB30 Deck Height - 9.075" (230.5mm)
Stroke - 85mm
Crank Throw - 42.5mm
Compression Height - 1.280" (32.5mm)
Using Spool/Argo Rods - 152.5 C/C
Deck Clearance = 230.5 - 42.5 - 152.5 - 32.5 = 3mm
Using RacingPartsFactory/Rod Factory Rods - 155.5 C/C
Deck Clearance = 230.5 - 42.5 - 155.5 - 32.5 = 0mm
Is that right by your calculations, therefore using either Rod, should not matter.
However, if you see an issue of deck clearance, you can always use RB25/26 pistons instead, as they have the same bore, but a smalled Compression Height
Edited by D1AUS
So that calculation above is wrong then??????????????????????
RB30 Compression Height - 1.280" (32.5mm)
RB26 Compression Height - 1.193" (30.3mm)
RB25 Compresson Height - 1.240" (31.5mm)
Using 152.5mm will yield 3mm Deck Clearance via that calculation
Using 155.5mm will yield 0mm Deck Clearnace via that calculation
Now thats even more confusing
Why not just use the Argo or Spool rods and be done with it? They both work without any issues?
Its not just a matter of simply using any rod. I'm trying to maximise the compression ratio etc with my setup. And with the calculations above and speaking to Distributor for CP in QLD.
Standard Rods have a 3mm deck height according to this calculation. As the CP RB30 Pistons are Dished not domed. Thats my arguement here.
Just trying to find out from others who have done this etc.
I understand Spool Rods are of good quality, but just seeing the available options to maximise the setup, thats all.
JD
Im building a 30/26 now with 9:1 comp using argo rods 152.4mm center to center
also using je custom piston compression ,height of 1.283,
0 deck height
havnt got the pistons yet but thats what i did to get the comp i want
0 deck height
Thanks for the feedback mate, I assume they are a domed piston????????
Im not trying to sell you my rods - just trying to explain that you are going to get in all sorts of shit of you use those ones with the 155.5 c/c
CP 8.2:1 are a flat top that come flush with the deck.
CP 9:0.1 are a domed piston. The flat of the piston come flush to the deck with a small dome in the centre.
CP RB30ET pistons have a small dish with valve reliefs.
To get 8.5:1 your prob best to use the 8.2:1 and skim the head - but obviously work backwards and cc everything first to calculate how much to take off the head.
Brad
By all means i do appreciate all your help, thanks very much
I'm just going by all the figures at the moment. Obviously, I will dummy everything up check chamber cc etc.
Just by the specs, thats what i get from the calculation. I know standard rod is 152.5mm
From your experience, what is the standard deck clearance for RB30? standard parts
deck height is 0 rod length should be 6"{152.5m} dont use any other rod length
and yes my piston will be dome
if u use the cp piston u can buy the right one off the shelf for 8.5:1 comp
u will only achive this if ur block height is standard and combustion chamber cc's are close to standard{65cc"s from memory}
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
