Age: unknown
Condition: good to excellent
To Fit: any
Contact: 0403008586 or pm me
Comments: all gauges come with all wiring / sensors, prices are pickup only, postage at buyer's expense
Item: Trust - Greddy GRACER Airinx-II Air Filters (Original Trust adaptors included to suit oem meters)
Age: less than 6 months old
Condition: as new
Price: $140.00 pickup $120
To Fit: (What car) R33 GTR
Contact: pm, sms or ring me on 0403008586
Comments: may fit other GTR models? can someone confirm this please
currently $220 at nengun delivered after 2 weeks wait, this is less than 6 months old
http://www.nengun.com/trust-greddy/gracer-...-ii-air-filters
Piping not included, only those circled!
04112007463qs0.th.jpg 04112007461hc0.th.jpg 04112007464ij7.th.jpg 04112007462lp8.th.jpg
Item: Red Line High Temp ATF oil (1quart/.94litres)
Age: new
Condition: Brand New , opened but unused.
Price: $15 pickup or can be posted at buyer's expense.
To Fit: was to be used on my R33 GTR but suitable for other cars?
Comments: GTR had a complete engine, gear and diff oil change and I unfortunately did not order enough for the transfer case. Ended up using some Castrol for this.
Item: Dunlop Le Mans 265/35ZR18
Age: unknown
Condition: used but still plenty of rubber
Price: $140 for the pair... pickup only SOLD!
Item: Duncan / Race Worx Attessa Controller
Age: received in the mail 06/02/08
Condition: Brand Spanker , never installed
Price: 350.00 pickup or posted for free SOLD!
To Fit: (What car) refer below thread
Contact: Jeff on 0403008586
Comments: Reason for selling is Im getting an ECU for the GTR instead.......
Group Buy thread
http://www.skylinesaustralia.com/forums/Fs...77#entry3637877
Item: R33 GTR rear pods
Condition: new
Price: $120.00 pickup (cost me $132.50) or can be posted at buyer's expense SOLD!
Item: Black HKS Exhaust Gas Temp gauge (60mm mechanical)
Price: $120 SOLD!
Item: HKS Turbo Timer
Condition: used but in great condition
Price: $70 $60 pickup or can be posted at buyer's expense. SOLD!
Item: White HKS Chrono DB Boost Gauge (60mm) + Meter Interface Unit
Price: $150 for both SOLD!
Item: Mearcat gauge holder to suit any R33 Skyline
Price: $30 SOLD!
Edited by jeff
https://www.sau.com.au/forums/topic/190818-trust-gracer-twin-filters-12000/
  • 3 weeks later...
  • 2 months later...
Age: unknown
Price: $140 for the pair... pickup only..dropped to $100 for the pair..
To Fit: was on my LM-GT1 (18"x10")
Comments: only selling due to needing to replace front tyres and ended up buying a matching set of 4 for my wheels
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
