hey all
anyone going to wsid next friday night for full throttle firday, im going to put my car in, hopefully it doesn't fill out to fast
should get a crew to go down and represent maybe, i dont know, post up if your going
Edited by weeman1
https://www.sau.com.au/forums/topic/190839-full-throttle-friday/
how busy is fri nights, have you been b4
nah haven't been before, shouldn't be any busier than a busy wednesday night, they only let 200 cars in i think, but racing starts at 6 and finishes at 11 so there's more time to get down the track anyway
Its storming at work (hornsby) ...... although seeing I won't have my car till tomoz no biggie... don't feel like im missing out now :)
If it clears up still planning on heading there to spectate.......
FROM WSID WEBSITE:
Rain Is A Pain - Tonight Cancelled, Next Full Throttle Friday Now December 14
Wednesday, 31 October 2007 by Dean Neal
Bring ‘ya Car, Or ‘ya Bike - Even A Bad-ass Racing Attitude To Western Sydney International Dragway Tonight!
Those Doorslammin’ And Top Bike Dudes On Nine Saturday, In-depth East Coast Nationals Recap Starts On Sbs Sunday Week!
October 20 Bracket Attack Results Now Available As We Head Into A Full Throttled Friday – This Friday!
Unfortunately due to large rainfalls throughout the greater Sydney area today and expected to further intensify - Tonight's Full Throttle Friday has been cancelled.
With a large number of events coming ahead on the WSID calendar already, it has been decided that the next Friday event will be as per the original schedule - Friday, December 14.
We would like to thank all competitors for their interest this week and we share in your annoyance at the rain putting paid to what was shaping up as a MASSIVE event.
Don’t forget, the first official Full Throttle Friday will now be FRIDAY, DECEMBER 14 with Competitors paying $50 for entry at the gate, Spectators $20 and racing action commencing from 6pm until 11pm.
Full Throttle Fridays
Ferrers Road, Eastern Creek
NEXT EVENT: Friday, December 14, from 6pm until late.
Pricing:
Competitors - $50
Adults - $20
Kids under 12 - FREE
EVENT INFO LINE: (02) 9421 0700
EMAIL: [email protected]
WEB: www.wsid.com.au
Please click HERE to check out the WSID MySpace Page!
PR Contact:
Dean Neal
[email protected].
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
