SO its almost the end of the year, alot has happened and what better way to wind down ready for the holidays than catch up with all the fellow hoons and have a cruise :P
Im thinking similar as last time with stopping for lunch/pictures/"play time" (all legal of course :P )
Im thinking early December if that suits everyone so post up if your keen and we can get the ball rolling.
WEEKEND OF DECEMBER 8TH AND 9TH
It would be great to get EVERYONE along to this if we can :):yes: :yes:
Cheers GMB
PS: who wants to lend a hand to get my car going :P
  • Replies 58
Im keen. Lets get a date organised asap so nobody can have an excuse for not being able to come due to other commitments.what about a cruise down the west coast?
The 8th suits me. have the hillclimb on the sunday too.
Edited by guesty
yes im mos def interested but would it be a 2 day thing or a one day thing. if its like a whole one day thing i could probably get the day off work. im definatley keen tho. just hope i can keep up!!
Hey guy's
Hows about the mega cruise heads to Baskerville on the 9th to catch the action from the final round of the TSS.
You could have the morning cruising and then the arvo catching the last couple of races
OR
Head there early and make it mini show and shine as you catch the action.
let me know what you guy's think :(:domokun::blush::blush::thumbsup:
RR
Hey Rosco,
Someone told me the last round was on the 2nd? mmmmm can someone confirm?
cheers
leigh
Hey guy's
OR
let me know what you guy's think :glare::yes::):ninja::w00t:
RR
Edited by woolls
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
