Hey guys,
Im thinking of putting some Volk GTCs on my R33 gtst but am stuck for offset sizes. If anyone has gone down this road can you please post up a pic or recommend me some wheel sizes! cheers
-Dragonforce
PS: any pics of GTC's on gtsts would help me heaps to!
Edited by Dragonforce
https://www.sau.com.au/forums/topic/190911-volk-gt-cs/
cant help you with pics but i must say, probly the best looking 33 i've ever seen was a clean stock series two dumped on gold GTC's
what colour is your car, what colour rims are you getting?
Mines a clean white series 2 with gold GTC's :)
I don't have pics yet with the rims on as i only chucked them on the other week but they look great.
Just so you know, i had to change all of my wheel studs to much longer ones to fit the rims on, this was an incredible pain in the ass!! Factor in around $140-$200 on 20 long wheel studs depending on where you get them from.
https://www.sau.com.au/forums/topic/190911-volk-gt-cs/#findComment-3441942
Ahh you guys are legends with the pics!
My car is a white Series 2. Was looking into getting silver wheels, Not really sure how flared gaurds will look on my car tho..
Don't flare the guards, it will look crap unless it's done really well by someone that knows what they are doing. But yeah the rims will look really good man :worship:
Edited by PM-R33
https://www.sau.com.au/forums/topic/190911-volk-gt-cs/#findComment-3462438
I had a set of 18 x 8 +30 all round on mine. I personally think more dish and if it was lowered a little lower they would have looked nicer... but at the same time i was happy with it :P
http://www.skylinesaustralia.com/forums/in...g&id=122257
http://www.skylinesaustralia.com/forums/in...g&id=122258
http://www.skylinesaustralia.com/forums/in...g&id=122261
https://www.sau.com.au/forums/topic/190911-volk-gt-cs/#findComment-3471799
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
