hey ppls
if anyone wants the shell from my r33 gtst s2 for free its yours :)
comes with all the panels and crap except rear/front bar and boot/wing.
it also has alot of crap thats under the main dash thingy. its got no wheels/hubs obviously so you couldnt quite push it :)
ONLY condition is....... ive got like a underground garage thingy and the door is just big enough for a 4wd to drove down, so a normal tow truck wouldnt be able to go down and get it. You'd prob need one of those little blue trailors.
If anyones interested i can PM pictures of it and also the garage/driveway.
need it gone real soon though, so tik tok :)
btw... cause its free i dont wana hear any whinging about this being in the wrong section :(
oh ya im in armadale.
https://www.sau.com.au/forums/topic/191067-free-r33-gtst-s2-shell/
Guest
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
