on a trivial note. if someone has one of these cars in brisbane I would like to have a fiddle with it. I'm considering doing the R34 ( I do the V35 now.) as well for nav,TV,DVD etc.
When you have worked something out with these i would be keen to find out mote info on this
  • Replies 42
  • 4 months later...
Its been a while since i tried doing something about the tv but now its a real pain in the ass!, everytime i turn my car on it opens up and a blue screen shows and i cannot put the screen down with ANY button, only way it goes down is when I turn the electrics off.
Is there anyone that has takin the unit apart that can shed more light on how to work this thing. There must be a simple way. Could the tv work with a different headunit? solso31 is your tv still working with dvd, ps2 etc?
Edited by MellowYellow
  • 1 month later...
sorry im new to all this but suming up..to watch tv you get a pal to ntsc converter and how do u play dvd/ipods? Any help would be greatly appreciated.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...N:IT&ih=008
^^^^^ converter
i am running a 12v-240v converter, aprox 200w i have the dvd player and converter pluged into it, when i want to play ps2 i just unplug dvd player and plug ps2 in
nope. you need a NEW TV tuner that outputs NTSC. from there you need to know what you are doing.
  • 5 weeks later...
  • 4 weeks later...
depends on how you want the system setup. in the case of nav + tv over $2k. yes I can do the nav in that car- I'm still assuming you are talking about a R34 GTR and NOT an aftermarket system fitted in that car. those are bin material.
Yes R34 GTR.
Is it worth the 2k+? The eclipse AVN 6000 double din H/U can be purchased for $2K with satnav facilities.
What navigation software does your 'work in Oz' system run?
Edited by DR-JEKL
garmin maps.
AVN is $2.5k before you add a reverse camera to it.
The AVN was $2K @ lifestyle car audio last week, and is advertised on their website for $2.1K.
Lifestyle
Thanks for your response, do you have any pics of your system installed?
Edited by DR-JEKL
  • 4 weeks later...
So basically for an R34 GTR to use the factory screen - it will still cost over $2k when you can purchase an off the shelf system for about the same price?
Is there any point to using the factory screen? Seems it would be more economical to just get a DVD unit/LCD screen and portable GPS setup than spend more to utilise a factory screen for the sake of neatness/integration.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
