on a trivial note. if someone has one of these cars in brisbane I would like to have a fiddle with it. I'm considering doing the R34 ( I do the V35 now.) as well for nav,TV,DVD etc.
When you have worked something out with these i would be keen to find out mote info on this
  • Replies 42
  • 4 months later...
Its been a while since i tried doing something about the tv but now its a real pain in the ass!, everytime i turn my car on it opens up and a blue screen shows and i cannot put the screen down with ANY button, only way it goes down is when I turn the electrics off.
Is there anyone that has takin the unit apart that can shed more light on how to work this thing. There must be a simple way. Could the tv work with a different headunit? solso31 is your tv still working with dvd, ps2 etc?
Edited by MellowYellow
  • 1 month later...
sorry im new to all this but suming up..to watch tv you get a pal to ntsc converter and how do u play dvd/ipods? Any help would be greatly appreciated.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...N:IT&ih=008
^^^^^ converter
i am running a 12v-240v converter, aprox 200w i have the dvd player and converter pluged into it, when i want to play ps2 i just unplug dvd player and plug ps2 in
nope. you need a NEW TV tuner that outputs NTSC. from there you need to know what you are doing.
  • 5 weeks later...
  • 4 weeks later...
depends on how you want the system setup. in the case of nav + tv over $2k. yes I can do the nav in that car- I'm still assuming you are talking about a R34 GTR and NOT an aftermarket system fitted in that car. those are bin material.
Yes R34 GTR.
Is it worth the 2k+? The eclipse AVN 6000 double din H/U can be purchased for $2K with satnav facilities.
What navigation software does your 'work in Oz' system run?
Edited by DR-JEKL
garmin maps.
AVN is $2.5k before you add a reverse camera to it.
The AVN was $2K @ lifestyle car audio last week, and is advertised on their website for $2.1K.
Lifestyle
Thanks for your response, do you have any pics of your system installed?
Edited by DR-JEKL
  • 4 weeks later...
So basically for an R34 GTR to use the factory screen - it will still cost over $2k when you can purchase an off the shelf system for about the same price?
Is there any point to using the factory screen? Seems it would be more economical to just get a DVD unit/LCD screen and portable GPS setup than spend more to utilise a factory screen for the sake of neatness/integration.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
