on a trivial note. if someone has one of these cars in brisbane I would like to have a fiddle with it. I'm considering doing the R34 ( I do the V35 now.) as well for nav,TV,DVD etc.
When you have worked something out with these i would be keen to find out mote info on this
  • Replies 42
  • 4 months later...
Its been a while since i tried doing something about the tv but now its a real pain in the ass!, everytime i turn my car on it opens up and a blue screen shows and i cannot put the screen down with ANY button, only way it goes down is when I turn the electrics off.
Is there anyone that has takin the unit apart that can shed more light on how to work this thing. There must be a simple way. Could the tv work with a different headunit? solso31 is your tv still working with dvd, ps2 etc?
Edited by MellowYellow
  • 1 month later...
sorry im new to all this but suming up..to watch tv you get a pal to ntsc converter and how do u play dvd/ipods? Any help would be greatly appreciated.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...N:IT&ih=008
^^^^^ converter
i am running a 12v-240v converter, aprox 200w i have the dvd player and converter pluged into it, when i want to play ps2 i just unplug dvd player and plug ps2 in
nope. you need a NEW TV tuner that outputs NTSC. from there you need to know what you are doing.
  • 5 weeks later...
  • 4 weeks later...
depends on how you want the system setup. in the case of nav + tv over $2k. yes I can do the nav in that car- I'm still assuming you are talking about a R34 GTR and NOT an aftermarket system fitted in that car. those are bin material.
Yes R34 GTR.
Is it worth the 2k+? The eclipse AVN 6000 double din H/U can be purchased for $2K with satnav facilities.
What navigation software does your 'work in Oz' system run?
Edited by DR-JEKL
garmin maps.
AVN is $2.5k before you add a reverse camera to it.
The AVN was $2K @ lifestyle car audio last week, and is advertised on their website for $2.1K.
Lifestyle
Thanks for your response, do you have any pics of your system installed?
Edited by DR-JEKL
  • 4 weeks later...
So basically for an R34 GTR to use the factory screen - it will still cost over $2k when you can purchase an off the shelf system for about the same price?
Is there any point to using the factory screen? Seems it would be more economical to just get a DVD unit/LCD screen and portable GPS setup than spend more to utilise a factory screen for the sake of neatness/integration.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
