Just looking for ideas, my car is not making the power it should be and hesitates at higher rpm when full boost hits. I have a hi flow turbo and thought this could be causing a boost cut but its only hitting 13psi max and was doing it with the std turbo at 10psi as well. The afm meter has been replaced and spark plugs changed.
im thinking that it could be a knackered fuel pump or maybe a coil pack?? any help would be appreciated
https://www.sau.com.au/forums/topic/19117-rb20det-breaking-down-at-rpm/
Similar problem to what im having at the moment. Ive also changed plugs, fuel filter, put a front mount on, and today i tested another computer, and setup an oil pressure guage to measure my fuel pressure and was also fine. The only things it points to now are one of the sensors is faulty, read this thread and do the diagnostics and see how it comes back, im guessing its a crank angle or knock sensor playing games :)
http://www.skylinesaustralia.com/forums/sh...&threadid=19018
Let me know how it goes, im doing mine tomorrow night :)
cant find that link dude?
did the fuel filter today, getting a new fuel pump soon but have to put that on hold because the car has started making the same sound it did when the old turbo was dying :) (a high pitched scream/squeel) im hoping its a gasket, only one left is manifold to head, changing it tomorrow fingers crossed. had nothing but bad luck thus far
let me know how you go with that cheers
That link is there, but it was under the topic Auto RB20 ecu on a manual or something like that by me. I did the diagnostics and it came back with a faulty knock sensor which would make sense why my performance on my car is poor. Have you found that after 5500rpm it looses a noticable bit of power?
The hesitation at high rpm is probably due to an over rich mixture and this seems to be a common problem with these engines. We found that at around 10-12psi mixture strengths of 10:1 are not uncommon and this causes the engine to flutter at high rpm and causes a noticable decrease in power, ideal A/F should be about 11.8:1 to 12:1. Re gap your plugs to .75mm,we have found that NGK BCPR6Es11 plugs to be about the best.It probably wont be a coil as this is generally indicated by a droped cylinder at idle speed not a high rpm miss.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
