Make:SKYLINE
Model:R32 Gtst
Milage:102k
Colour:Black
RWC supplied?if needed
Currently registered?Yes
Price:11,500 ONO
Contact:0431242703
Comments / Modifications:I am the first Australian Owner of the car, ive had it for about 1.5 years
Interior
Custom Black and Grey leather interior (retrimmed standard interior)
Autotechnica steering wheel
Hks Limited Edition Turbo Timer
120,000km's on the clock (to be honest im not shure how exact that is like with all imports.. they change the dash)
Interoir parts have been professionally resprayed in this garold orangy red colour
Rear vision reverse sensor parking kit installed aswell (on the rear view mirror a picture of a car comes up showing you the distances etc, might not be there if i decide to get a kit for the car)
thats all i can think of atm
Engine
Deltafin Intercooler kit
Genuine Blitz Air Filter/pod
Billet Hks oilcap (lol)
3inch catback 5zigen zaust (not loud at all but when its opened up its sex)
Drivetrain
Exceedy Xtreme heavey duty cushion button clutch 9 puk, has had about 11-14 thousand kms (still tight)
thats all i can think of atm as i havent driven the car in yonks
if i do sell the gearbox will be replaced
and a brand new bosch 040 fuel pump will also be installed (or i can just give it to you as part of the deal so you can see its brand new and put it in yourself)
i have never ever boosted this car since ive had it, its been on standard boost
no mayjor crash history only thing the rear right quarter panel, at the bottom its moved in about 2 cm barely noticeable.. i clipped a mound of snow
i have standard airbox and cooler also
asking 11,500 grand ono
Cheers
Interior
Edited by bLaQ.bOi
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
