Dyno Day
67 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 326
Posted Images
Cubes
got 2 more names for ya from 31 club (forum names for now anyways, lemme know if ya need to contact them)
SLW-031 and
NUGZY!
thanks mate
yeah im sure keen for the day.
i wouldnt mind signing up membership to the club too. then i can get my cams licence :(
Hey Matt,
No problems buddy; I won't put any more down on the list as its getting fairly large; basically on the day those that haven't prepaid its first in first serve. So get the $$ to me asap on the day to secure your spot.
We will be running a total of 25-30cars. 2 runs per car.
We are nearing the 30car maximum but as with all dyno days there's always the few that decide not to go on the day or simply forget. :thanks:
I've just received a pm from a dude called natoe aka slw 031. He wouldn't be one of the ones you mentioned would you?
Hey Matt,
thats cool mate, i'll let them all know
as for natoe (SLW-031), thats one of the guys i mentioned yeah.
guys i got a question
im not 110% sure if my car will actually be running on the day but im very keen so whats the go with that ?
if i rock up due to cars still running will i get told no bad since im not confirming payment , or can i pay at the place just have to wait the line ?
Those that have paid get priority when they want to run.
So if you have paid and rock up at 12:00 and want to run your the very next car on.
Those that haven't paid its basically if you hand the $$ to myself first then you get on the end of the paid list to run when you want.
If that makes sense. :whistling:
I wouldn't be too concerned as people always rock up late and some people simply don't turn up.
With regards to club sponsorship etc. We have discussed its best not to do so until the club is up and running with a member base.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
