BMW
740iL
169000k
5spd Auto
Orient Blue
Sydney
Jan 2008 Rego
$21000ono OR swap for Car of Interest
0420560838
Car is immaculate.
Pwr Windows,mirrors,seats,sunroof,head lights.
19inch late model 7 series wheels.
TV, On board computer, Cruise, Dual zone climate control.
Heated mirrors.
Electronic anti glare rear view mirror.
Electronic rear blind.
Car phone.
Auto leveling suspension.
So many more features!!!!
0-100K in 6.5sec!!!!
Used to be the Danish Ambassadors car! (log books)
More pics can be emailed if serious buyer...
https://www.sau.com.au/forums/topic/191390-bmw-740il-v8-luxury-sedan/
The M5 is a great car.... goes like the clappers (not in GTR league but still enough to embarass the LS1 commonbores) and sounds fantastic.
Why do you want a primitive V8 when you've got an E38??? :rofl:
hehe, its my fiancee man...
she hates it, thinks its too big...
hehe, hey if it doesnt sell Im not exactly worried...
extractors and exhaust coming if I keep it. :rofl:
My S62 sounds like this
http://users.on.net/~sa145/Eisenmann_M5.wav
with an Eisenmann Race exhaust.
your M60 would be rather close :)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
