  • Replies 42
Posted Images
Ended up heading out and running a 11.8 @ 117mph.
Humid as night out there, saw a few skylines racing too which was good, but never really had the chance to chat to anyone.
"Ignition" DVD wanted to do an article on my car but I politely advised there's no way i'm getting in front of the video camera haha
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447689
nice work. i saw your car there but never saw it run. My best for the night was a 11.194 @126mph. Didnt beat my 11.056@127mph from last time though. Thought i was goin to on my first run tonight as i got a goood launch with my best 60' time of 1.683 but missed 3rd gear and only ran 12.19 @109mph :D ohwel might head back friday if the weather is good
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447833
290kw@4... it's only running stock cams / cam gears, so need to get those upgraded, which should help :rofl: Still you've got almost 60kw@4 more than me though so i'm not getting a low 11 haha... nice work!!
Nah I didn't (I heard the burnouts were starting so started packing up). Heard it hit both left and right wall? Nasty shit :D
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447880
yeah i was lined up waiting for my last run but didnt see it happen, just heard everyone and saw everyone running. yeah from what i know after it crosed the line for an 8.6 he lost control and hit one side then across into the other.
what turbos are you running? id like to crack a 10 but i dont know if i can on the tyres im using
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3447891
congrats on the time. What kind of 60' were you doing. must of been pretty average
2.3-2.4 around there.
Still trying to get the revs and clutch work down.On the night i was dialling up 3500 and slightly dumping it.Can really ride the cushion button.
Any imput would be appreciated.
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3451977
get some MT et street radials and that will be a big help.
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3452029
Tomm0 that's a very very nice GTR you have there, noticed it in the pits as I did my usual rounds.
Thanks for the compliment :)
All photos are up too guys.
http://www.cacklingpipesphotography.com/07...treetmeet_1.htm
http://www.badgerphotography.com.au/2007/S...71031/index.htm
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3454211
off the subject, did you notice much differnce when you put in the statinless steel split dump pipe? and did the flage marry up with the exaust?
yeh i really think the tires let me down.They were some old SAVAs i had in the garage.Could hardly get smoke with a second gear burnout.
https://www.sau.com.au/forums/topic/191457-wsid/page/2/#findComment-3459448
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
