this topic came up on another forum i'm on, and Ben from J-Spec said the same thing..
that bus with the non turbo 13B was used in a hilly region... how it even got up a hill I'll never know, must have been pretty depressing. Still, only something like 10 of them were ever made so rotary collectors were gaga over it, from memory the seller wanted over a hundred grand.
it boggles my mind why you would combine such a heavy chassis with an engine with no bottom end torque.
because GM and mazda had dealings going on back in the 70's and GM 'genoursly' donated a bunch of chassis to mazda, a gift of sorts. thats my understanding of it anyway
http://www.j-spec.com.au/list/5143
we came across a bus a while back that had over 1 million genuine km's on it.
yeah 20B would go alright, no lack of torque from them, they make like 450nm or something last time i checked?
ahahha i just wanna see that bus with a maztec (or similar) built 13B, big single, external gate, launching off the transbrake and holding just that little bit of angle (on slicks of course) the entrie way down the 1/4
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
