is it??? i was under the impression u could completely remap ur entire fuel air curve from idle up, either way i have ordered mine wether it goes in my car or not is a different story, but if and or when it does i will post up dyno sheets and make sure to get runs and figures for before and after.
haha yep, i got mine for just under 530 bucks australian from an american company and thats delivered and its the series 2!!!! and they are like 750 to buy here what a bargain i can almost get mine fitted and dyno'd as well without paying more then what there worth to buy here.
the adjusted fuel curve comes into effect above 80% throttle usage. below 80%, its just the normal curve set by the factory.
when u guys go get your safc, write down the settings because the factory 'may' re-adjust itself after installing and tuning the modual.
i had a mate with an R33 gtst, he got his fitted and dyno tuned for $100, but this price may be cheaper if he bought the unit from the same people
hey man, just use a search engine, put it "s-afc II" and "sale" and it will come up with heaps of places between 300 - 330 american, which by the time u get it here works out to be a bit over 500 bucks. i think i got mine from supra store online.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
