Hey guys and gals, i've just recently joined the the forums, and I'd like to introduce myself. My name is Roald, but you can all call me Roo.... its easier :)
Now, I don't drive a skyline, but i do have a RB30DET (25/30) in my VL Calais, and I figured this would be a good place to get some good info on the newer nissan tech, as the VL sites i've become accustom to are more 'SOHC oriented'....
I have some Q's regarding my setup etc. but I'll get to them at a later date (studying....)
Looking forward to getting involved,
Regards, Roo ;)
https://www.sau.com.au/forums/topic/191734-new-act-member/
  • 4 weeks later...
Ok, so its been a while.... I've been busy finishing my CIT course - flat out!
Here are some pics and info from the prevoius owner. I would have loved to do the conversion myself, but this came along and was far more cost effective :)
Engine
7,000 km's old
3ltr, acid cleaned, crack tested
bored and honed 50 tho to suit oversized pistons,
shot peened rods. New mains, big ends, small ends, balanced etc.
genuine Nissan head gasket
reconditioned RB25DET cylinder head with extra provision for VCT,
ceramic T3 turbo driven only on 6 psi
3inch exhaust with high flow cat
New bosch 910 fuel pump
Custom braided lines for turbo
Nizpro engine bay mounted intercooler
Wiring harness professionally modified to suit vl
Gearbox
R33 turbo 5speed manual box
Pulled down for inspection before fitting
Short shifter
Harness and speedo modified to suit vl
Heavy duty clutch,
shaved flywheel,
Fully balanced and modified drive shaft to suit r33 box
148RWkW and 530Nm on 6 PSI, std. R33 computer :)
Will get more pics up later on some time.
Cheers, Roo
https://www.sau.com.au/forums/topic/191734-new-act-member/#findComment-3502555
148rwkw? :huh:
Are you sure that figure is correct? You should be making a lot more than that...
No offence intended.
None taken :) .The reason for such odd Power vs. Torque figures is due to a rather restrictive intercooler. Between about 2100-3300 rpm I have access to full boost (10p.s.i), but by the time I've reached 4500 rpm its all the way back at 6 p.s.i :) You can see on the dyno sheet where the boost really falls off. Once its gets up on the revs, the cooler simply can't flow enough air.
Correct me if I'm wrong, but I think this setup should really start singing at around 4000/4500 rpm, right where its all over....
I'm condisering sending the cooler to Garrett for a recore (Nizpro tanks are good as far as I know?) and getting the turbo high-flowed/steel wheels. Any other recommendations? Will I need a fuel cut defender (sometimes it surges/cuts under boost at lower revs - i.e. full boost to manifold) or rising-rate reg?
Thanks for any input,
Roo
https://www.sau.com.au/forums/topic/191734-new-act-member/#findComment-3507884
None taken :P .The reason for such odd Power vs. Torque figures is due to a rather restrictive intercooler. Between about 2100-3300 rpm I have access to full boost (10p.s.i), but by the time I've reached 4500 rpm its all the way back at 6 p.s.i :( You can see on the dyno sheet where the boost really falls off. Once its gets up on the revs, the cooler simply can't flow enough air.
Roo
If I may voice my opinion... :)
Well if you want to get the most from your engine set up (RB25 / 30DET) then I would suggest a fairly large low mount turbo such as a Garret GT30 / 82R, dont bother high flowing the one you have.
Im using a GT30 / 71R (slightly smaller than the 82R) and it is good for about 250rwkw, the larger GT30 / 82R will be better for your engine because you have more down low power because of the larger capacity and it will probably spool a larger turbo pretty quick.
If youre going for out right power then you will need a fuel pump - go for a Walbro in tank or Bosch 040. You'll also need to upsize your injectors as the standard ones will max out pretty quick, go for some SARD 550cc brand new squirters, dont bother having the standard ones high flowed.
As for your intercooler, I have been using a Just Jap / Cooling pro 300 x 600 x 76 front mount for a while and Ive never had a problem, I would highly recommend one for the price.
Get in contact with GCG in Sydney for the turbo, Powerflow injection for the pump and injectors and Just Jap for an intercooler.
Im using similar equipment in my RB25DET (550cc injectors, 040 pump, GT30 / 71R and JJR front mount) and my car makes 230rwkw and 550nm at 18psi, very conservative AFR and it has bugger all lag.
:D
Edited by Bullet32
https://www.sau.com.au/forums/topic/191734-new-act-member/#findComment-3517303
Great, thanks for the info :P
For the moment its on hold due to a matter of funds, but I will definitely take your advice into consideration. I have been considering dropping the whole lot into an R32, but again this is more likely to happen later rather than sooner, once I finish my apprenticeship :P
BTW, anyone know what a good R32 rolling shell might be worth, just out of curiosity?
Cheers, Roo
https://www.sau.com.au/forums/topic/191734-new-act-member/#findComment-3524527
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
