R33.5?
hey guys,
been doin some thinking, is there anyone in Oz that makes a 'bolt on' r34 front end to fit on an r33, similar to that of the 'strawberry face s14-15 conversion.. im talking lights, front fenders, front bar all that sorta thing. has it been done or is it just more custom work than ya can poke a stick at??
its only so expensive as u need to do headlights, front bar, bonnet, guards, reo, and all the f*#king around getting ti to line up properly then also to spray it. the kits are about 3-4k in glass, the other 4-6k is spent on fittup and spraying as there is some work needed to get the headlights to fit and then the guards to have a consistent gap and yeh. alot of mucking around.
R33. SKYVIC -
civic front end on a skyline ;)
haha
ive seen a few pics of r33.4 and theyre pretty nice.
LOL wtf? Who would put a civic front on a skyline? ahaha
I understand if it was the other way around, skyline front on a civic, but civic on a skyline? >_<
 Share
    • 6.3-8.3nm....pretty damn light those fine m6 threads in the aluminium retainer plate are very easy to strip
    • What are the torque specs for those 6 bolts on the retainer plate and 4 oil pan bolts? I'm currently tackling this job during an auto to manual conversion... I thought this would a 5 minute job!
    • Tryna decide if I should get a skirt coating on my cp 2618 forged pistons that im about to order. Anyone have first hand experience with a forged RB with coated or non coated piston skirts? Is it worth it and does it make much difference? And for people who went with 2618 pistons with no skirt coating how long has your engine lasted? The engine is an rb25/30 and main concern is  that It will be a daily car and will probably see a fair bit of short distance driving, have been told by my machine shop and my tuner that generally a forged engine lasts around 40,000kms before needing a rebuild. Would a skirt coating make much of a difference? cheers
    • From now on read it as minus 5 and minus 7 instead of dash, and you're correct...
    • Opened up the cluster to inspect the gauge itself for signs of damage and it looks good. Got curious since that needle doesn't go back to a "neutral" position by itself (it stays in the same position when ignition is off. so I manually moved it to 1/2. Connected it back, turned on the ignition and the needle started moving up! Not sure what's up with that but before that the needle was way down below empty like fully south west. There's always a chance that the needle moved slightly the first time I tried and I didn't notice because of how slowly it moves and how far it was from the markings. I don't know if the current needle position is accurate so I'll fill it up and see where that brings it. I guess I'll try to adjust it manually if it doesn't get to F. Looks like the needle position is relative and not absolute? Thanks all for your help and patience!
