In all the N/A applications where I have fitted extractors the power gains were only in the order of 5 odd kW, but performance was gained in faster peaking and flatter torque curves. For most turbo applications again peak power is only maginally affected (10 odd kW) when boost is kept the same. But usually a free flowing exhaust will allow slightly higher boost pressures dues to faster turine speeds. This coupled with the increased spool speed and flatter torque curve make for much happier driving.
  • Replies 43
Just reading this intresting thread, I too am looking at ways to get more power out my GTS25 and getting the best bang for my bucks. I found a thread on the SDU forums, that may help answer a few questions. I hope you find it of some use.
NA Power
Cheers
Rach
If your interested in maximum bang for buck then have a look at this http://forums.vwvortex.com/zerothread?id=776885
How ever if your intending to keep your car drivable, then what we've discussed so far are the best options.
1st: make the car breath easier; fit free flowing filters and duct maximum velocity/vulume air at minimum temperature at it. Fit a free flowing exhaust system that has suitable backpressure for the engine type and modifications. (N/A cars need exhaust back pressure for optimum cylinder fill).
2nd: Fuel and ignition systems; Factory setups are always on the rich side to give better life span. Fitting piggy-back computer or replacement ECU's will yield fantastic results when tuned properly.
3rd: Component modification; I suggest starting with the head and examine porting sizes, shapes and their match to manifolds. The cam is also a good source of more power. From there look at your deck and head mating surfaces for more compression. Next is the inlet manifold which can always do with some tweaking.
4th: Component replacement; once at this stage you probably need to look at stronger rods, domed pistons, a new inlet manifold, larger throttle bodies and even bigger valves.
5th: Sell your house and go nuts!!!!
But remember the old saying:
Performance costs money, so how much do you want to spend?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
