  • Replies 77
Posted Images
yes it is bursons,they have a website but they dont have an online catalogue, but you call 1300burson
and ask for a fender roller.$175
they are all over australia, the closest one to me is seven hills , sydney
Another company can get them for 200 is AUTOLAC
They both have a 2 day wait on them cause they are shipping them up from melbourne ( same distributor )
That just about wraps it all up, now i have to get the tool and perform surgery on the guards
Keep you all posted!!!!!!!!!
ima gonna go to the penrtih one tomorrow and order one i think .. $175 is too good a price
Why are they so cheap? I would've thought they'll be at least $400, but $129? That's crazy cheap.
I'm just gonna wait till the Christmas sales. :whistling: I don't even have a licence or a proper car I can drive yet so no point buying it JUST yet.
Well i just picked mine up
normal chinese tool, but still sturdy and looks like it will do the job pretty well. hopefully i'll find some time soon to test it out
ended up getting it for $145 from burson's in penrith
was changing some upper control arms, so while the wheel was off i bolted the unit on to get a feel for how it worked, fits good and will do the job.
there will be alot of adjusting involved since the wheel arches arent a perfect circle
also need to remove the calipers to get the unit to do a full sweep.
heres a pic - not bad for $145
  • 2 months later...
Myself & a mate flared the guards on my S14 a month or so back.. Im running 18x9 +25ish on the rear of the car with the 265's which came with them & I have my car on the deck.
Her'es something different if your ballsy enough to try it :) worked awesome for me...
We used a jack handle first with a heatgun to roll the inner lip slowly driving back & forth.
Then once the inner lip was rolled we got 2 sheets of thin Ply, 2 very thin pieces of aluminium & a scissor jack for the flaring.
Put the scissor jack in your wheel arch & wind out so that it has alluminium then wood pushing against your guard slowly heat the arch & keep increasing the tension on the jack & it will push your guard out.. you will have to move the jack 3 or 4 times so you get an even flare but the results were excellent.. I got about an inch out of my guards with no cracking, so now I can fit my 18x10 +18's :D
Pics below... If any of you have seen standard S14 guards you will appreciate how much flare we have got in the 2nd pic..
http://img141.imageshack.us/img141/9025/flarejx1rb3.jpg
http://img136.imageshack.us/img136/1746/flare2mo1li4.jpg
http://img100.imageshack.us/img100/6962/toolsoh2to7.jpg
Edited by Shypo
We custom rolled my guards with a piece of round metal pipe lift car up put pipe in then roll the car with handbrake off worked well for free and about 5 mins work each front been done to au falcon too with custom paint worked quite well, i was like maybe abit dodgey but once it was doene came up a treat and 10 minutes i can do lol
  • 1 year later...
there are heaps and heaps of threads on this dude..
no it wont screw anything up.. maybe your paint on the lip but thats it..
rolling and flaring are 2 different things. and both are only done to the outer skin... not the inner guard if thats what your referring to.
Yeah, don't want to flare.
dont waste your money on the burson tool its a heap of shit, mine threaded on the first guard about 5 passes in. next time id pay someone else to do it. however i have welded a few nuts and a new bolt onto the burson tool and it has improved it out of sight.
and craved, the washers on the handle are to go under the wheel nuts. if anyone was wondering?
Edited by 32_Dave
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
